Question about install rear struts - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 04-06-2014, 03:21 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:224
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
Default Question about install rear struts
I was looking to put some new struts all struts on the truck. What is the best way to install the rear ones. I know it should bee strait forwerd two bolts but how do you get to the top one in the rear. I felt up there and noticed that the frame of the truck looks to be in the way.
Any help would be nice.
Thanks
Old 04-06-2014, 09:11 PM
bstc00's Avatar
Color: Inferno Red
Rep:224
Anyone?
Old 04-08-2014, 12:11 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
The rears are not struts. Just shocks. The passenger side is pretty straight forward. I have the quad cab and on the driver side the gas hose is right next to the upper mount. It was a PITA. Took a lot more time than I had planned. It also depends on what shocks you are mounting. I installed the Fox 2.0 shocks. They are not compressible by hand. So, the truck has to be lifted until the lower mount is even with the shock. I expect the Bilstein 5100's are the same. If you are replacing the stock shocks with new twin tubes you can probably compress them by hand and get them into the lower mount without having to jack up the truck too much. It wasn't fun. Just stick with it and you can do it yourself.
