Old 04-07-2014, 01:46 PM
tweener439's Avatar
tweener439 tweener439 is offline
Vehicle: 1997 Dodge Ram
Rep:12
tweener439 is on a distinguished road
Default Newbie front suspension question
So I just finished replacing my track bar, all tie rods, upper and lower ball joints, and shocks and I still have a chatter that occurs when I'm going 60+. It does not rattle the steering wheel but I can feel the frame chattering. There is no pulling or mishandling of the truck, just the chatter at 60+mph. It seems to come and go depending on either a hard left or right turn. I'm wondering if its the front stabilizer bar and/or stabilizer link arms. Any help would be appreciated.
Old 04-12-2014, 12:38 AM
Lazarus Truck Lazarus Truck is offline
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Hi Tween! What is the condition of the hub bearings? Do they pass the tests? How about the wheel joints? Did you replace these? I did this in my first Ram by beating them out. I bent the yokes doing this. Got a vibration I couldn't find, or fix. So you say it comes and goes with hard right and left turns? Hub bearing. If you do find that you you need hub bearings, try Amazon, and use the Timken bearings. Much better than the crap you can get at Autozone. Seriously, jack the truck, and wiggle the wheel. That should tell you the health of the bearing. There should be NO play.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 04-12-2014, 01:02 AM
aprfct0's Avatar
aprfct0 aprfct0 is offline
Vehicle: 1997 Dodge Ram 1500
aprfct0 is on a distinguished road
I agree with Lazarus on this one if the condition is worse when turning it is most likely the hub bearings. If the hub bearing is ok, then I would start looking into the steering stabalizer. What size tires and when was the last time they were balanced?
Old 04-13-2014, 01:47 PM
tweener439's Avatar
Rep:12
I'll check for wheel play this week, I doubt its the tires they are pretty new and the problem existed before the new tires. I'm running 285/75 15's. Thanks for the replies.
Old 05-10-2014, 11:32 AM
njoenks's Avatar
njoenks njoenks is offline
Trim Level: Laramie SLT
Color: Burgandy/Silver
njoenks is on a distinguished road
I had a ford 4wd that had some of the same symptoms, I also replaced ball joints, tie rod ends shocks, wheel brgs and anything that was part of the front suspension, but I believe the main problem was my front U-joints and a set of $7.00 plastic bushings.
Old 07-13-2014, 04:19 PM
PricePass PricePass is offline
Vehicle: 2001 Dodge Ram 1500
PricePass is on a distinguished road
I hear you about the bushings. I had aftermarket shocks on
The front and the bushing was completely gone off both. Instead of replacing both front shocks, spent $10 at Advance Auto and the difference is amazing. Bushings wore out prematurely. Saved myself about $300.
Old 07-13-2014, 08:33 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Rock Auto is also a good source for parts and their shipping and customer service is great. 2 days from order to receive in Ontario, Canada.
chatter, front suspension
