Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
ZDOG
Old 04-08-2014, 11:33 AM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2014 Ram 1500 cc 4x4
Trim Level: Outdoorsman
Color: Granite
Rep:32
finn5033 is on a distinguished road
Default Effect of wheel/tire weight increase
My trucks stock wheel/tire weight was 77lbs. If I increase that to 84 lbs how much should I expect my mpg to decrease? Both tires are A/T's so there shouldn't be any difference there. Any help would be appreciated. Thank you.
Old 04-08-2014, 12:44 PM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:17
Hemi HFE is on a distinguished road
there are a lot of factors here, and you provided very little information;
If the Only change was an increase in wheel/tire weight,
Then you will see a insignificant -> slight 0.1-0.2 mpg decrease in City FE,
with negligible/no impact on Highway FE.
But,
If you change tire height (outside diameter or revs/mile) then yuo change the gearing, and height (which impacts aero).
If you change the tire width, then you change the frontal area (aero).
If you change tire model, brand, 'tread style', or even load rating (P -> LT), you change the tire's rolling resistance.
Even changing the wheel 'style' will change aero...
etc.
These are all small, nearly insignificant changes, but they can add up..
And typically when you switch from OE to 'larger' you Worsen every one of these -
(except for the gearing) ...
Then you get posts like "lost 1.5 mpg with tire change ! WTF?"
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 04-08-2014, 12:50 PM
finn5033's Avatar
Color: Granite
Rep:32
Ok here is all the info. I had the stock 17x7 aluminum wheels with the stock size 265/70/17 goodyear wrangler silent armour tires 10ply. I went to a 20x9 wheel with stock size 275/60/20 falken rocky mountain A/T tires 6ply. My aftermark et wheels weigh the same as the factory chrome clad 20's but the tires weigh 6 lbs each more than the goodyear SR-a's
Old 04-12-2014, 01:59 PM
Juma Juma is offline
Vehicle: 2014 ram crew cab
Trim Level: Tradesman
Rep:13
Juma is on a distinguished road
My ruleofthumb calculus would be every pound of unsprung weight is worth 10 pounds so that's 6x10x4 equals 240 pounds more. So, I'd say about .5mpg-1mpg if everything else is equal.
Old 04-15-2014, 03:16 PM
canadian.bacon's Avatar
canadian.bacon canadian.bacon is offline
Vehicle: 2014 RAM
Color: Deep Cherry Red
Rep:121
canadian.bacon will become famous soon enoughcanadian.bacon will become famous soon enough
whoa that sounds a lot....
Is the overall diameter the same?
Old 04-15-2014, 09:44 PM
Rep:17
I believe that rule of thumb is intended for drag racing ..
I have heard another 'rule of thumb' that says 1# rotating (not quite the same as 'unsprung') = 4#
so that would be 4 x 4 x 6 = 96 #
Old 04-16-2014, 05:09 PM
Rep:13
I should have said rotating. Unsprung really applies to road racing. Weight on wheel is like weght on a fly wheel. Matters big time. I think it's pretty certain that 20" wheels hurt gas mileage. But, mostly in town driving cause you are stopping and starting up again all the time.
