Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-11-2014, 10:24 AM
Dan70 Dan70 is offline
Vehicle: 1995 Dodge Ram 3500
Color: Blk
Dan70 is on a distinguished road
Default Heater doors
The doors that control the flow four heat and a/c open and close on there own? Any body no whats up with that?
Old 04-11-2014, 07:56 PM
RogerRamJet's Avatar
RogerRamJet RogerRamJet is online now
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I believe on the second gen Rams, the HVAC was controlled via vacuum lines. Perhaps you have a small leak.
Old 04-16-2014, 12:25 AM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Could be. With low, to no vacuum, they should revert to defrost. Safety feature.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 04-25-2014, 05:34 PM
Andrewsdad Andrewsdad is offline
Color: Emerald Green
Andrewsdad is on a distinguished road
Dan, The first thing to check is pretty easy. Find the check valve on the vacuum line that is located right at the intake manifold on the passenger side. (It looks like one of those little low-flow water drippers on a garden watering system.)
Remove it and see if you can blow thru it. It should only pass air in one direction.
If it fails, a new one is readily available at car parts stores.
Good luck and let us know how you make out with it.
AD
Old 04-29-2014, 03:28 PM
audiophile's Avatar
audiophile audiophile is offline
Vehicle: 1998 Dodge Ram 1500 Club Cab
Color: Blue
audiophile is on a distinguished road
I am having the same issue except mine is stuck in defrost. I will check this out as well. Mine is also not cooling and the a/c clutch is short cycling. Freon pressure seems to be okay according to the gauge that I have.
They say hard work never killed anyone, but why chance it?
Old 05-02-2014, 02:46 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Check to see if any of the vac lines are cracked and check to see if the metal lines for the 4x4 actuator is rubbing on something.
If you hear any "hissing" from the hvac panel, you need to tear it apart and re-grease the plastic diaphragm.
Old 05-07-2014, 12:03 PM
TexasTim TexasTim is offline
Vehicle: 2000 Dodge Ram 1500
TexasTim is on a distinguished road
I am having a very similar problem. I have noticed when I run my A/C that it will switch to heater while driving. I can hear what sounds like a door moving under the dash when it switches. If I turn of the A/C wait a few seconds and turn back on the A/C will work again.
I have been trying to determine when this happens and I think its when the RPM's drop but not always. I will be checking the check valve and looking for any cracks in any hoses.
Besides checking the hoses in the Engine compartment and the check valve are there any other recommendations. I read something about the blend doors having problems in the 95 - 02 dodges. Heater Treater has a replacement part they say fixes a lot of Heater / A/C issues. Any thoughts on that? Here is the link. http://www.heatertreater.net/magento...ram-95-02.html
Thanks in advance for any help.
Old 05-08-2014, 11:08 AM
tomcatg tomcatg is offline
Vehicle: 1998 Dodge Ram 4x4 Sport
tomcatg is on a distinguished road
I purchased the heater treater part but haven't installed it yet. Gonna replace my cracked dash and while everything's apart going to install heater core and the heater treater part at the same time.
