Old 04-11-2014, 11:58 PM
Jasonball16 Jasonball16 is offline
Vehicle: 1994 dodge 1500 5.2L RWD
Jasonball16 is on a distinguished road
Default 94 ram 5.2L randomly shuts off while driving
i have a 94 dodge 1500 5.2L that will randomly shut off while I'm driving. It will start back up but only after like 5 minutes trying to start it. it will always crank, all of my electric is still on so i don't think ignition switch, i changed my oil and spark plugs and i put a new crank sensor in it a few months ago when i put a new tranny in. It will just completely shut off while driving and then start a few minutes later and drive fine. also another thing, i was driving it today and my rpms dropped to 0. my engine was still running and i could still rev my engine but it wasn't making me go faster, then the rpms shot back up and it drove normal. i am a mechanic and even this is stumping me, please help, i need this things running asap! thanks guys
Old 04-12-2014, 01:41 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I'd suspect crank or cam sensor.
Old 04-12-2014, 07:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I beg to differ Gen1. What you mentioned IS a possibility, however; the first thing I'd check is the ground strap from the engine block to the firewall.
Old 04-12-2014, 08:09 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
My first thought would be the coil. But you said one time it was running but showing no RPM's and would rev but wouldn't accelerate. It could be a lose ground like Warlock said, but usually if something is jarred lose, it has to be jarred or bounced back. Like Gen1, I am thinking a sensor as well, but more like the throttle position sensor because of the reving without accelerating issue. It sounds like something is heating up and failing, then when it cools down, works again. I would try the tap test on the ECM. When it's running, tap on the ECM with a large screwdriver handle. If it dies, you know you have a bad ECM.
Old 05-02-2014, 02:12 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
An alternator overcharging will shut the truck off.
panhead's Avatar
Trim Level: WS
Rep:103
Double post
Old 05-09-2014, 01:35 PM
njoenks's Avatar
njoenks njoenks is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Burgandy/Silver
njoenks is on a distinguished road
I had similar symptoms in a 86 dodge van. My problem ended up being the ignition wiring harness. It was a 12 inch pigtail located along the bottom side of the steering column. What happened was the connection had overheated and allowed the contacts to move around losing contact resulting in the engine dying and not restarting till the connection had cooled enough to make contact again. It cost approx. 35.00 to replace the pigtail.
cuts off randomly
