Dodge Ram Decals
Old 04-12-2014, 08:59 AM
highwayman1's Avatar
highwayman1 highwayman1 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Tradesman
highwayman1 is on a distinguished road
Default Rear lowering question
Well, I'm thinking of lowering the rear about 2-3 inches on my long bed 2-wheel drive. The question is how to lower it without drooping if loaded. I do have 500-550 lbs in it for winter traction and don't want it to sag ,when loaded. Can I use lowering springs in conjunction with air bags? And since I live in Illinois, the winter does have effects on air lines (I know this from driving a semi). Any suggestions? Thanks in advance.
Old 04-12-2014, 06:51 PM
audio1der audio1der is offline
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
Yes, airbags work fine with lowered trucks. I am -2" in the rear and I use the bags they recommend for stock height without issue. You could probably use them for up to a 3" drop.
I tow our 32' trailer all summer and even with the drop, 700+lbs of tongue weight, 2 kids and all our crap in the bed she sits nice and level, with a comfy ride.
Airlift 1000 FTW!!
If you're uneasy about which bags to use, call Airlift. Tell them the inner diameter and height of your springs and they will give you the part# of an application that will work.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 04-13-2014, 09:50 AM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:17
Hemi HFE is on a distinguished road
I plan to install Airlift 1000 rear bags with my McGaughy's 2/4 drop kit...
As I understand, the '05+ Durango are the bags to get;
same I.D., couple inches shorter...
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
