Old 07-06-2014, 09:50 AM
Power247's Avatar
Power247 Power247 is offline
Vehicle: 2012 Ram 2500
Color: True Blue
Rep:22
Power247 is on a distinguished road
Thanks man! I used fiberglass chop mat. I found in my previous project that the woven cloth did not work as well.
Greg
2012 2500 4x4 CTD Big Horn CCSB 3.73|Flo~Pro|SIMS|XRT Pro|Edge Insight CTS|Infinity|JBL
2009 1500 4x4 HEMI Big Horn CCSB 3.55|Volant CAI|18" Magnaflow|Airlift1000|Superchips Flashpaq 3865 - SOLD
Old 07-07-2014, 12:59 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
I just did my cab as well, but i got little more crazy
Ran new wire as well.
album: http://imgur.com/a/Vtlh4
2016 F250 Lariet FX4 CrewCab 6.7L
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted - SOLD
My Build Progress
Old 07-07-2014, 01:24 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
I know I looked at this tread before and told you you did a fantastic job but dam I had to tell you again......FANTASTIC WRITE UP AND JOB
Old 07-07-2014, 02:44 PM
Power247's Avatar
Color: True Blue
Rep:22
Nicely done! You definitely got better coverage by taking of the inner door panel... I just couldn't bring myself to do it. I was able to get most of teh area covered by cutting into smaller strips and reaching in through the access/speaker holes. I am hoping that covering the inner door panel will help make up for it. Even if not it is still an improvement over what comes from the factory
Greg
Old 07-07-2014, 02:48 PM
Power247's Avatar
Color: True Blue
Rep:22
And again I thank you for the kind words. I have learned so much about this truck on the forums, I enjoy the opportunity to give a little back too.
Greg
Old 07-07-2014, 02:54 PM
Color: Blue
Rep:156
I was nervous about taking the inner door panel off but you take 3 hex screws out for the locking device. unclick the rod from the door handle and unclip the window and pull it out.
THen it is just unboltt he inner door skin and your done. Its honestly a lot easier then you think, since everything is attached to the inner door skin you only have to remove couple pieces.
My Build Progress
Old 07-26-2014, 10:05 PM
Power247's Avatar
Color: True Blue
Rep:22
Default Upgrading the front door speakers
I finally decided to do something about the door speakers. I went with some Infinity Reference 9632cf's from Amazon. The speakers and Metra harnesses came out to about $75. I figured that they were cheap enough that if they made no noticeable improvement I wouldn't be the end of the world.
Installation was a breeze with the Metra harnesses. Probably 30mins start to finish and that was only because I needed to find longer screws. There were a set of plastic spacers included which I needed for the magnet and basket to clear the window mount... hence the need for longer screws.
Some of you are asking... was it worth it??? Honestly... yes. Even with the odd crossover config being applied by the factory amp... they blend very well with the 3032's in the dash. They add just enough to help fill the gap that developed when I upgraded the dash speakers and sub.
By the pic you can see they are a noticeable improvement of the 'premium alpine' speakers supplied by the factory.
These speakers are just what I needed to keep me from gutting the whole system... hopefully
Greg
Old 08-09-2014, 09:01 AM
dengland dengland is offline
Vehicle: 2014 Ram 1500
Trim Level: Limited
dengland is on a distinguished road
Did you buy 2 or 4 3.5" infinity 3032s?
Old 08-09-2014, 03:50 PM
Power247's Avatar
Color: True Blue
Rep:22
Only 2... still running the factory 3.5" in the center.
Greg
Old 08-09-2014, 06:03 PM
Trim Level: Limited
Bummer. I am hunting an unattached 3032. Having trouble finding a reasonably priced pair. Thanks
