Old 04-12-2014, 10:48 AM
brguzz's Avatar
brguzz brguzz is offline
Vehicle: 2012 Ram 1500 Sport
Rep:17
brguzz is on a distinguished road
Question Using 9005 LED bulb for highs/DRL (Voltage Issue?)
So I would like to use a set of LED 9005 bulbs for my DRL and high beams since I don't use my high beams anyway. The problem is that the DRL use half of the voltage of the normal high beams so it uses 6V instead of 12V which will not power the most LED bulbs. I was wondering if anyone has done this yet or knows of a way or a bulb that compensates for this. Thanks Brandon
2012 White Ram Sport
Old 04-12-2014, 03:31 PM
Flyfisher Flyfisher is offline
Vehicle: 2012 Dodge Ram Sport
Color: Blue
Flyfisher is on a distinguished road
I have been thinking of doing the same thing. Also want to use the H11 LED but not sure which one will work.
Old 04-12-2014, 04:19 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I just ordered a set of these http://www.automotivelightstore.com/...maLEDBulb.aspx to replace my highs. Guess I'm the Guinea pig so I'll report back once I give them a try. It says that they are direct plug and play and can be used for DRL so hopefully their advertising is correct.
Old 04-13-2014, 10:32 AM
brguzz's Avatar
Rep:17
Keep us posted. Much appreciated. If you could posted some pictures of the DRL on and high beam on that would be great too. Thanks
Old 04-23-2014, 03:10 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Talking
Okay so the plasma LED 9005 bulbs work perfect as Highs and DRL. I still need to get some pics to post. The turns I got from ACC also work perfectly. I was impressed the DRLs work and no error message on the EVIC either.
Old 06-08-2014, 01:49 AM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
Did you ever get some pics?
