Old 04-12-2014, 01:26 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
Default heard tap sound...new mod to come now
last friday driving around I could hear a tapping sound echoing off other cars. When I got home I popped the hood and could definitely hear something, decided to tear it apart thinking something in the valvetrain (like a lifter) was causing this...with over 255k miles on motor I figured a lifter was going bad since it was the original stock ones. I pulled the timing cover and found that my chain tensioner broke and the piece was just sitting there... so then I decided to order a new tensioner, then timing chain since this was also the original. Then ordered new lifters and also a new oil pump...then my mind got to thinking more with the motor opened up and needless to say, I now have a 392 stroker assembly on it's way , also, since my 214/218 Spartan cam was worn, decided to get a bigger 230/240 bump stick too... this is going to be a fun build
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 04-12-2014, 05:49 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
This is gonna be fun!
Supercharged, cammed, other things too!
Old 04-12-2014, 06:02 PM
huntert's Avatar
huntert huntert is offline
Vehicle: 2009 dodge ram 1500 ST
Color: Austin Tan Pearl
huntert is on a distinguished road
Sounds like this will be a very fun project! I will be watching this one for sure.
Westin black step bars, Diablo intune, 35x12.50x18 Nitto Trail Grapplers, 18x9 -12 offset MAYHEM CHAOS wheels. 2.5 inch dual exhaust with a custom made x-pipe before dual dynomax race bullets, topped off with rectangle tips.
Old 04-13-2014, 02:55 AM
chefred112's Avatar
Rep:656
at least the torque converter swap is gonna be REALLY easy...lol
Old 04-13-2014, 03:05 AM
chefred112's Avatar
Rep:656
I believe this caused the original problem...broken tensioner...
but the lifters were worn..
which in turn wore out the cam..
but the heads look great..all those miles and no sludge..
even the pistons looked good...but ima gona swap them out anyways
Old 04-13-2014, 05:33 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
that thing is surprisingly clean!! Look forward to seeing more of the build!
Old 04-13-2014, 12:17 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Fred, are you going to use the 6.1 oil pump? I've been told that the stock pump if marginal if you shift over 6,000 rpms and I shift at 6200. After seeing that, I think I'll change out my tensioners at 200,000 ! I'll be interested how that new cam works out.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-13-2014, 02:10 PM
dodgeram2007 dodgeram2007 is offline
Vehicle: 2007 dodge ram 1500 slt
Color: charcoal
dodgeram2007 is on a distinguished road
I have heard a tapping sound in mine and was told by the dealer all Dodges make that "knocking sound" is this true and should I be worried??
Old 04-13-2014, 02:21 PM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1739
Nice can't wait to see this!! So will you be changing your signature from -fast freddie- to -faster freddie-
Old 04-13-2014, 02:57 PM
Rep:2616
dodgeram2007
There are different noises that are common to different engines
The HEMI engine is known for the infamous HEMI TICK, which commonly happens at initial start up, after the engine has been sitting overnight, it usually disappears within a minute.
