Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 04-14-2014, 06:35 PM
Redhemi03 Redhemi03 is offline
Vehicle: 2003 hemi ram
Trim Level: Slt
Color: Flame red
Rep:26
Redhemi03 is on a distinguished road
Can you not hold it in 4th manually at the End of the track? And are in tow Haul and manually shifting or what?
2003 QC HEMI. 8.46@ 79.50, fastest NA 03 QC
Sidewinder cam, power wire,Tmr delete, edge 2800, hedman long tubes , Hedman ory pipe, 3" cutout, magnaflow 24", k&n CAI,Sharadon stage 3 VB, 4.56's, superchips 91
Old 04-14-2014, 09:40 PM
black ram 00 black ram 00 is offline
Vehicle: 2014 ram 1500
Trim Level: blacktop express
black ram 00 is on a distinguished road
Default mph
iam in tow haul
don't know if there is a way yo hold it or shift man. don't think i would make it in 4
Old 04-15-2014, 10:01 AM
Trim Level: Slt
Color: Flame red
Rep:26
Lift those shift points and that shouldn't be a problem, a programmer might do you alot of good
Old 04-16-2014, 12:45 PM
Default mph
just installed lowering kit shorter tires and programer next on list lookin for 13.80s
Old 04-16-2014, 03:16 PM
buick455 buick455 is offline
Vehicle: 2013 Ram crewcab 4x4 8 Speed
Trim Level: Outdoorsman
Color: Mazerati Blue
buick455 is on a distinguished road
My 2013 ram 1500 4x4 outdoorsman crew cab full of stuff, with 8 speed that i towed my dragcar to the track in temple texas with, Full tank, And a hot motor bone stock, ran a 15:03 at 89mph. ran it down the track to help dry the track 10 times after a shower. I got 6 time slips. the slowest was a 15:60 with 4 people in it.
Old 04-21-2014, 09:17 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
what tras do you have? I have 4.10 gears and 29" tire and I cross the line in 4th gear.
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-21-2014, 11:57 AM
Default mph
i have the 6 speed but i can't hold it in 4th and it shifts @ 5600
Old 04-22-2014, 03:01 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
I ran 96 mph with my 6-speed 3.55's.
Put the shifter in D, then hit the "-" down til it says 1. Then floor that bitch on the last yellow. It will shift itself to 2nd gear on its own so don't touch the shifter yet, then as soon as it shifts into 2nd, push the "+" up to 3, and let it shift to 3rd, it will only drop maybe 500 rpm on that shift, then run it up and hit "+" to 4th and then let it hold 4th gear til you cross the line.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 04-22-2014, 03:18 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If you have a Diablo tuner, should be able to raise shift points. I shift at 6,200 rpms. With the cam in my 05, hp peaks at 6,000 and stays pretty flat till 6,200.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-22-2014, 05:17 PM
Default mph
just got my tuner really disappointed no way to adjust sift points or line pressure they said it is not avaliable for the 2014 with 3.92 no way i can make it in 4th with 31 inch tall tires shifting @ 5600
