Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 04-22-2014, 06:29 PM
black ram 00 black ram 00 is offline
Vehicle: 2014 ram 1500
Trim Level: blacktop express
black ram 00 is on a distinguished road
Default mph
Criss you sure your tires are only 29 i have the same drop as you and yours look taller
Old 04-22-2014, 06:30 PM
Default mph
Chris you sure your tires are only 29 i have the same drop as you and yours look taller
Old 04-22-2014, 09:54 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Originally Posted by hydrex View Post
If you have a Diablo tuner, should be able to raise shift points. I shift at 6,200 rpms. With the cam in my 05, hp peaks at 6,000 and stays pretty flat till 6,200.
This was done through your custom tune? I have to check where my shift points are at with my current tune
Supercharged, cammed, other things too!
Old 04-24-2014, 09:37 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Yes, the pics on here is a little old. im ruin 265/35/22 now
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-24-2014, 09:39 AM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-24-2014, 08:41 PM
Default mph
must be the wheels i have 17 with a 31 inch tire just installed the t1000 can't adjust shift points really dissapointed 93 performance tune did nothing still went through in 5th @4200 rpm
Old 04-24-2014, 08:45 PM
Chris did you run the 93 performance tune before having Sean tweak it if so was there any differance in the performance
Old 04-27-2014, 03:17 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
I've never really paid much attention to mph, ET wins the race
My fist 13 sec slip was May 2011
intake/catback/Diablo 93 canned tune and a set of 28" drag radials
5 speed trans shifted at 6200 rpm, cross traps just as it shifted into 3rd gear if I used 2nd prime upshift
10' RCSB 4x4 with 3.55 gears,
DA ranges from 2500' on a good day to 5000' in mid summer heat.
(13.4/101 after DA corrections at DragTimes)
Later that year with an Edge 2800 stall TC,
...quicker launch (1.8's for my 60') but top end got slower for some reason
latest slip on a dying trans finally broke into the 100's (left lane)
Old 04-29-2014, 09:10 PM
reicos's Avatar
reicos reicos is offline
Vehicle: 2013 Ram 1500 Sport
reicos is on a distinguished road
BlackRamHemi you going to be at the track friday night?
Old 04-29-2014, 09:24 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Yes, Sean Powell (hemifever) worked with my dyno tuner guy TDP. Raising to 6200 made a hell of a difference, also the 3,000 rpm stall converter. Mine peaked over 6,000 rpms with this cam, shifting at 5,600 was a waste. Be interesting to see where you peak with that cam,
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
