Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 04-14-2014, 08:12 PM
mwang mwang is offline
Vehicle: 2014 ram 1500
mwang is on a distinguished road
Default rust converter, any thoughts/experience?
Hi Mates
I bought my truck last October and rust proofed it. winter has passed, and yeah, there are some rusty spots here and there. no complaints, it's a truck made of steel with exposed frame. I tried to sand off the rust and spray on some protective coating, but hell yeah it was hard to craw under the truck already. so now I'm thinking of those rust converters, it seems all you need to do is to spray and wait for it to convert. has anyone used it and is it any good?
Thanks
Old 04-14-2014, 08:37 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
It turns black when it reacts with rust. I spray everything under the truck with "Fluidfilm" after hitting the rust with converter. Sprayed inside frame, dropped spare and blast behind. Blast inside doors and don't forget to remove fender liners, and blast the "Fluid Film" or "Kroil" behind them as well as inside rocker panels. You can do it if you put it on jackstands, but easier if you get her on a lift.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-14-2014, 09:01 PM
Rep:2657
mwang
Make an appointment with your local KROWN RUST PROOFING location
many of the members in here that are from Canada use this product
you may look at a product called POR-15 if you just want a converter
