Old 04-15-2014, 06:36 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
Default Ball Joints again?
ok.
so i never really looked all that closely when the zone UCAs were installed two weeks ago, but i thought id take a look underneath the truck today to see how everything is holding up. am i loosing my mind, or are these ball joints now coming unseated from the bottom?
im guessing they are not because the top seems to be in place, but it does look weird...and of course i beleive i feel a little rattle and clunk when turning the wheels in the front...
thanks!
Old 04-15-2014, 08:13 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
It's hard to tell unless you know how they were positioned at the time of the installation. Ball joints, like other parts, are made to fit more than one application. In this case, maybe they're longer to fit different thicknesses of UCRs. Try marking it with a grease pen to see if there is any further movement.
If there is, then you have a bigger problem than just ball joints. Something is out of whack. No way you go through two sets, with two separate set-ups, in such a short period of time...
Good luck.
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 04-15-2014, 08:26 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Sorry to see this Jeff, hope you get it sorted out.
Old 04-15-2014, 08:29 PM
Rep:910
good point about the universal ball joint...its excactly what it is. it is a raybestos balljoint in the Zone UCA's.
im glad you guys arent having any issues with your ball joints...maybe because ive got the 2.5 " spacer. im almost ready to pull them out and order the bilsteins again. i had zero issues with them in my 2010.
Old 04-15-2014, 08:30 PM
Rep:910
thanks man...this may not be an issue, but i thought it looked strange. id like to hear from someone else with the zone UCA's to see if they noticed the same issue.
i cant for the life if me think they have come out at the bottom when the top looks fine.
Old 04-15-2014, 08:40 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Normal, here's a picture of someone else on this forum that just had a set installed....
Old 04-15-2014, 09:08 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Rep:156
Man that is some clean under there! Must not drive it.
S S H A D O W
Old 04-15-2014, 09:20 PM
Rep:910
thanks boosted...now maybe the rattle will go away too!
and mine is filthy after 2 weeks! and snow again today!
Old 04-15-2014, 10:05 PM
Boosted's Avatar
Rep:219
Rattle could be a hundred different things. At least you can have some comfort in knowing your UCA's and balljoints are fine.
Old 04-16-2014, 01:18 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Whew! What is it will ball joints now days? Dodge isn't the only ones with issues, the F-150's go through them like crazy too.
