Old 04-16-2014, 06:45 PM
jrnannery jrnannery is offline
Vehicle: 2009 Ram QC SLT 4.7L 4x4
jrnannery is on a distinguished road
Default Rear bumper sensors
I am having an incredibly difficult time finding a chromed rear bumper with exhaust cut outs and sensor holes. Can you just drill the holes yourself, or not?
Old 04-17-2014, 08:52 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Yes you can drill the holes and make sure you get the holes in the same place. The sensors come with the drill bit. Go slow with the hole saw. You may need to get 2 bits do to getting dull. Use some silicone cocking to seal from rusting before installing the sensors.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 04-20-2014, 10:59 PM
padillavp padillavp is offline
Vehicle: 2012 Ram 1500
Color: mineral gray
Rep:19
padillavp is on a distinguished road
I would like to install the rear backup sensors on my try what all do i need to purchase to get them to work, sensors ,wiring etc. ?
Old 04-21-2014, 12:52 AM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
Not sure you can have Ram do it and intergrate it into your EVIC, but you can always ask a dealer if they can.
If you don't want to go the dealer route you can find plenty of kits from $40 to $200 depending on how far you want to go. Rear only or front and rear for park assist. If you want chrome sensors they are available from some suppliers. Check Ebay or Amazon or do a search on the web. Chrome sensors http://www.sonicelectronix.com/item_...7C-Chrome.html
It is not hard to drill your own as the kits provide a hole saw. The biggest problem is lining them up and spacing them properly.
Tape off the bumper and measure then mark the location. Check alignment and location as many times as you feel comfortable, once drilled it is drilled. Punch the centers of the holes and drill pilot holes before using the hole saw. Treat the drilled metal so it won't rust, insert sensors, run wires to cab, hook up wires, find a location you like for the display unit, that's it.
Old 04-21-2014, 01:36 AM
Thanks.
