Old 04-16-2014, 06:20 PM
BradZ's Avatar
BradZ BradZ is offline
Vehicle: 2011 Dodge Ram QC
Rep:23
BradZ is on a distinguished road
Default you guys up for a little garage advice?
Right now I pull into my garage, I gotta stop and fold in the drivers side mirror to get into my garage. My antenna hits on the door frame but other than that I'm good. I initially wanted to turn my 2 door garage into one big door which didn't seem too difficult as it doesn't appear to be a main support between the doors.
I also have been thinking about making it a bit taller and I'm wondering if that's even possible.
I snapped some pictures for reference.
From the front of my garage here's the doors
which started my grand plan
From up top it doesn't look like turning it into one big door would be an issue, least not to me, but I'm not a construction kinda guy
Also you can see the floor in there, I'm THINKING that just raising the doors would be more than enough space but I don't know how far I can go.
Up on the doors there's a beam above either door that doesn't seem to have any purpose to me.
So what do you guys think, can I get a door about the height of that ceiling? Even more anybody ever try to raise the ceiling of a garage so there's room to jack a lifted vehicle up?
With the door opener gone from above my truck I think I'd be able to have more than enough room to park anything I wanted in there so it may work out really well with the added clearance of no door mechanism.
Old 04-16-2014, 06:35 PM
Rep:2657
I won't hazard a guess about those beams above the garage doors
Above mine there is a 4x10 & they don't put those up unless support is needed
10' in from that, i have a 8x10
I do have an apartment above my garage & the other 3 garages too
4 apartments all together
1 above the garages, 3 on ground level
Old 04-16-2014, 06:47 PM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
one big door you would need to header the entire opening
you could gain height by adding a row or two to the bottom of the garage with brick if its not attached to a house ect ...
Old 04-16-2014, 06:50 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
You can't go much higher... if at all, but you could probably use a laminated (manufacture beam to span the distance) and install a larger door. Looks pretty simple from the pics... Actually, the doors look like 8'x7'. A doubled-up 2"x12"x18'+ should work as well to accommodate a standard 16' garage door.
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 04-16-2014, 06:59 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
I would have a local building contractor have a look to see what can be done. If you have any of the original building plans, that would probably be a big help. You may be able to get a copy at a local land registry department. After you get a professional opinion you may be able to do the work yourself.
Old 04-16-2014, 07:45 PM
BradZ's Avatar
Rep:23
I figure we're going to need a contractor, but I don't want to even bother if it can't be done.
Looking online it seems like all the standard sizes are 7ft tall. Love to be able to get another foot in height out of that.
Old 04-17-2014, 06:28 AM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:38
rcmpvet is on a distinguished road
I am not sure about your state or local codes, but here in Canada most would require a building permit as you will be altering structure. As it is a header beam up there already you may well requires an engineer's report and solution.
Your structure is A-Frame over the garage, there is a beam spanning across the garage door opening.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
Old 04-21-2014, 09:04 AM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I can't hurt to ask a contractor to take a look at it and give you a quote. From what I see I would say theres a 99% chance you can't go any higher, if it's possible you would have to alter the roof line. The only advantage you will gain with a single door is maybe not having to fold the mirrors in but you're going to have to get close to the other vehicle in the garage to do that.....you're going to ding one eventually!
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
