Old 04-17-2014, 11:04 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
x3
Air/Fuel ratio is not a standard Diablo parameter available for data logging or monitoring through the Ram OBDII port.
But it is possible to make it one if you're willing to go through the trouble and the cost...
First you need a Wide Band gauge from a reputable company ( I have an AutoMeter )
with a bung welded to your exhaust for the sensor...preferably before the cat on the drivers side down tube.
Then you need wideband pigtail (RCA connector) that is tapped into the gauge,
and plugged into the mini RCA analogue input on your Trinity.
Diablo Sport - T1015 DiabloSport Trinity Analog Pigtail Cable
Then you setup the Analog Input configuration in your Trinity
You Tube instructions here:
That's What RIPP is expecting from you to remote tune your A/F ratio.
A Dyno Tuner (CMR) will often use a tail pipe sniffer to measure your A/F ratio, so no need to have a wideband installed.
Old 04-17-2014, 07:53 PM
chris41623 chris41623 is offline
Vehicle: 2011 ram 1500
Trim Level: Big horn
chris41623 is on a distinguished road
Has anyone gad tyranny issues with their ripp supercharger
Old 04-17-2014, 08:49 PM
Rep:554
Everyone I know with a Ripp kit has smoked their stock transmission, (mine lasted 2 months)
and upgraded to a "Built" one from Mike (aka MGH) at L&M Customs (including myself)
$2500 if he modifies your transmission, (frictions,pump,valve body and custom tuning)
+$500 if you want him to supply a used core (you keep your stock trans)
+$1000 if you want an upgraded Torque Converter with better holding power (ATS Triple Disc 3000 stall)
some good reading on Ram transmission options here:
http://www.ramforumz.com/showthread.php?t=141021
http://www.ramforumz.com/showthread.php?t=124821
http://www.ramforumz.com/showthread.php?t=146929
http://www.ramforumz.com/showthread.php?t=153656
Old 04-17-2014, 10:22 PM
Very helpful thank you
Old 04-18-2014, 07:47 AM
How much psi are u running with upgraded trans
Old 04-18-2014, 09:16 AM
Rep:554
8psi , I can go higher just by increasing my shift points up a couple hundred rpm.
But it's not recommended unless you're running Water/Meth or forged pistons.
Stock Hemi pistons are not really built to handle more than 4psi. (narrow ring lands)
I setup my system on the advice from Mike at L&M customs.
More info on Water/Meth for Boosted applications here:
http://www.alcoholinjectionsystems.com/
more in my build thread:
http://www.ramforumz.com/showthread.php?t=65939&page=24
Old 04-18-2014, 09:21 AM
I'm currently running 7 ..is it worth going up just for on psi..different pulley n blow off I guess all I need
Old 04-18-2014, 09:30 AM
Rep:554
Do you have a w/m setup?
Don't go higher without it, you're already in the danger zone over 6.
...you are also going to smoke a stock transmission a lot faster
Old 04-18-2014, 12:07 PM
Wat is water meth for..Wat does it do..tyranny is almost smoked..we're is l m located for trans..
Old 04-18-2014, 12:46 PM
Rep:554
I gave you a link already to read up on Water/Meth aka Alcohol Injection
here it is again...
it helps keep you from doing this to your poor stock pistons/rings
when you're running more than 6psi...
Reduces air charge temperatures by 50-150+ degrees
  • Reduces cylinder temperatures by up to 300+ degrees
  • Increases your 87-93 octane pump gas by 8-20+ points
  • Allows you to safely run more boost and timing
  • Longer more stable combustion expansion and progression
  • Removes carbon build-up from combustion chambers, pistons and valves
  • Reduces and helps eliminate engine damaging detonation and pre-ignition
  • No need for expensive racing fuel or additives
Protect your motor and the investment you have in your motor with one of AIS’s water methanol injection systems. Have questions or need technical help choosing the right system? Give us a call at 1-801-447-ALKY(2559). It’s 100 Proof Performance!!
For a Boost Proof transmission, L&M Customs out of Delaware...
Mike Herbert (aka user name mgh on the forum) shoot him a pm,
I think you'll see several of his posts in the transmission links I posted.
here's his profile page: http://www.ramforumz.com/member.php?u=28255
and his Twin Turbo Build thread: http://www.ramforumz.com/showthread.php?t=83155
You can also contact him by phone
(he has no website)
L & M Customs
113 Sunshine Lane
Middletown, DE 19709
1 (302) 449-5225
