Old 04-17-2014, 01:07 AM
auburnfan's Avatar
auburnfan auburnfan is offline
Vehicle: 2002 Dodge Ram 4x4
Trim Level: Sport, SLT
Color: Gray
auburnfan is on a distinguished road
Question 4.7 to 5.7 change?
I have a 4.7L v8 2002 with a 4 speed transmission, and I'm looking at replacing the engine soon due to it having more than 200,000 miles and it just doesn't run as good as it used to.(it still can get up and go, but after racing my friends 05 with the hemi, I realized how much of a difference the hemi makes.) I have gone through not kidding at least a hundred threads and have heard conflicting reports. So some say you can replace the 4.7 with a 5.7 hemi.... is that possible and if so, what all would need to be replaced, and how much do y'all think id be looking at to do all of it? And I really don't want to strip a wrecker dodge cause I want reliable parts and have some kind of warranty on it.
Old 04-18-2014, 08:46 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
If they repeated what they did with the gen 3s, then what you'll need is a scrap harness to use for modifications to the stock harness. The motor mounts for the hemi from the dealership, which may be 2-4 (depending on 2wd vs 4wd) different parts. And I'm not sure how programming has progressed on the different years for gen4, but gen3 just simply needed new fuel maps programmed onto the 4.7 computer and all was good.
It's very likely that the frame brackets are exactly the same on the 4.7 and 5.7 trucks. The difference will be in the isolater bushing and the bracket that mounts to the engine block, which is why I say you will only need to go to the dealership and get the correct parts for the 5.7
The wiring harness modifications aren't that bad at all, the biggest pain is the EGR because it's on the back of the drivers side head on the 4.7, but on the front of the passenger side head on the 5.7, and it's 6 total wires to splice it. Some wires have to be lengthened and others moved to the other side of the harness, and there may even be a connector or two that will need to be swapped. Also, the knock sensor connectors will need to be lengthened and switched since the 4.7 has the sensors on top of the block, and the 5.7 has them on the along side skirt of the block.
And as far as EGR goes, it should be possible to just leave that connector dangling and block off the EGR port on the hemi head with a billet part from shophemi.com. Then have it programmed out of the pcm.
You will also need to change the separator plate/dust shield that goes between the transmission and engine block, as well as the inspection plate (or structural collar as Chrysler calls it)
And make sure to get dowel pins to go in the engine block if the 5.7 doesn't have them when you get it. (the pegs that stick out of the engine block, and slip into holes on the transmission to aid in alignment)
Old 04-18-2014, 09:21 PM
auburnfan's Avatar
Color: Gray
Thanks, I really appreciate the answer, hopefully i'll have it done by the end of the summer
Old 04-19-2014, 01:12 AM
Rep:2968
Good luck with it and keep us updated.
Old 04-19-2014, 03:08 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
AEV can put a hemi in a jeep, so no doubt this can be done. with reg oci, 4.7 can get 300000 miles. i would would keep it.
4.7l engine, engine swap, hemi 5.7
