Old 04-17-2014, 01:00 AM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Default Body, rocker panel replacement using adhesives and welding.
Hi folks. In the next few weeks, I will be doing another rocker replacement on the right-side of the 2G Ram using a minimum of welding, and mostly structural body adhesive (glue) to accomplish the job. I did the left side last year as a learning experience, and it turned out well enough that I feel I can actually help some folks with this. I work at a car factory, and I can attest to today's body adhesives. The advantage of the glue is that the lower seam will be completely sealed, and should never rust. I will also be doing some mig plug welding that may help others in their skills. I am NOT a bodyman. Just a guy that reads, and watched Youtube videos for help. If some of you have interest in this, I will be happy to document it, and post a step-by-step on how I do it. After all, we are all here to either learn or share. Next month, I will be doing a rear wheel-arch repair the same way. If this is something you would like to see, let me know, and I will try to document it as well as possible. I'm glad to help if there is any interest. Laz.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 04-17-2014, 03:34 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Sure, post up. As a retired boat builder, I agree, some incredible adhesives out there. Been able to keep my 05 pretty rust free with "Fluidfilm" and a "Counter-Act" rust buster.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-30-2014, 10:33 PM
Rep:194
Thanks Hydrex. Began the dis-assembly today, pulling the fender and drilling spot-welds with a Blair spot-weld cutter. The door will have to come off to get full access. Lots of work, but great reward when it's done!
Old 01-27-2015, 05:28 PM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
Any pictures of the work?
Old 01-31-2015, 01:31 PM
Tot202's Avatar
Tot202 Tot202 is offline
Vehicle: 1999 dodge ram 4x4
Trim Level: laramie slt
Color: flame red
Rep:19
Tot202 is on a distinguished road
would like to see your step by step on the rear wheel arch i will have to do this repair hopefully this summer and have an idea in my head on how to do it but always good to see different perspectives on the repair
Old 01-31-2015, 10:42 PM
Rep:194
Happy to help. I will try to put together a slideshow with notes. I started with a Sherman part as they are usually 1.2mm as opposed to some of the other MFR's that are 1mm thick. Usually you will find the inner metal wheel-well with some holes in it. patch it as you see fit. Some tools and materials are,
Spot-weld cutter, 5/16"
Weld-through primer
Seam sealer
Plug welding pliers
Spring clams (harbor freight)
Abrasive "flap-wheel" for your angle grinder. They make less heat
Thinnest cut-off disks you can find
Welding magnets
I'm not that good a posting pics, but I will try to make a thread in this section over the next week. I have plenty of pics from the job. Thanks for the kick-in-the-ass I needed to get going on this.
