Old 04-18-2014, 12:17 PM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
Default Header installation?
I have a set of headers to install on my truck and I also have a Vararam intake currently on my truck. I just purchased an S&B cai and will be replacing the Vararam with it. Would it be easier to install the headers with the Vararam on as opposed to the S&B since the S&B takes up so much space beside the engine. I`m going to get a shop to do it and I don`t want to pay extra for them to have to move stuff out of the way and the Vararam leaves easier access to the headers from the top if needed.
Old 04-18-2014, 01:03 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
almost 99% of the Header install "should" be through the wheel well
(removal of front tires and fender liners required) and from the bottom.
Only thing I needed to pop the hood open for was to disconnect the battery
Old 04-18-2014, 02:02 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1049
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I gotta agree with BRH for the most part,i have the S&B intake, i know on my 2005 that the intake bolts to the wheel well liner. That being said it took literally 3 minutes to remove that bolt and and then everything else was done on the underside.
Old 04-18-2014, 04:44 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
Exactly what those two said. Having said that, I'd leave the vararam on for the install JUST IN CASE the shop needs to remove the S&B for whatever reason. Just makes is easier, and they can't charge you an extra half hour or so.
Just my opinion.
