Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-27-2014, 12:44 PM
numb1zero's Avatar
numb1zero numb1zero is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: ST - Quad Cab - 4x2
Color: green
numb1zero is on a distinguished road
Thumbs up
Originally Posted by Lazarus Truck View Post
Relax. Nobody said "cracked block" yet. The JB weld repair I mentioned was on the aluminum timing chain cover that serves as the water-pump base. You can see the area I'm referring to in photos 5 and 6. Clean and dry this area, then rent a radiator pressure tester from one of the auto stores. Pressurize your system to 16psi and inspect these areas closer for seepage or drips. Its alot easier doing it this way, than on a hot, running engine.
Oh, phew! that sounds like a reasonable repair and a hopeful next step. Thanks, i'll let you know how it goes. Sorry to be dramatic, I was getting concerned.
2001 Dodge Ram 1500 CrewCab 5.2l V8 Magnum
2014 Kawasaki Ninja ZX-3R
