Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-21-2014, 07:27 AM
Kingface Kingface is offline
Vehicle: 2014 Ram !500
Kingface is on a distinguished road
Originally Posted by pinebeatle View Post
So are you spraying oil under the body?? Ive heard of people doing that but was not sure if it was true. If you are oiling under there can you explain the process to me--Many thanks
Would like to know how to do this as well!
Old 04-21-2014, 10:40 AM
pinebeatle's Avatar
pinebeatle pinebeatle is offline
Vehicle: 2014 ram 1500
Trim Level: SXT ++++
pinebeatle is on a distinguished road
Yes Very much so --Cheers
Drinking Rum before Noon makes you A Pirate , Not a Alcoholic
Old 04-21-2014, 11:51 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Silver is the easiest colour to live with. I'll admit that I wasn't huge on Silver when i picked my truck up, but it has grown on me. My bud's with black trucks are always asking if I washed my truck, they are shocked when I tell them its been 3 weeks. They barely get down the road without becoming dirty again.
IG:@briley59
Old 04-21-2014, 08:37 PM
hslager69's Avatar
hslager69 hslager69 is offline
Vehicle: 2008 dodge ram 1500
Trim Level: sxt
Color: red
hslager69 is on a distinguished road
Ya i spay everything under the truck with fluid film,fluid film can be sprayed on rubber components as it won't hurt them.You have to get in every nook and cranny,the rust prone spots are above rear wheels,front box corners ,cab corners and front fenders.A lot of guys bring their trucks into so called professionals to get oiled but 99 % of them don't get complete coverage in the critical areas.the area above rear wheels is a bad area,there is the outer sheet metal then an inner support that traps dirt and moisture ,the oil has to get between there most shops don't bother.I now have a hoist so i have an easier time oiling it but it is possible to do it on the ground as i have done it for years .you can do it with fluid film sold at most hardware stores in aresol cans but i now buy it in 5 gallon pails.in the USA you can get it here- http://www.kellsportproducts.com I also spray inside the doors ,you have to drill a few access holes but you can buy plastic plugs,Id rather have to drill a few holes and oil than not bother and deal with rust.When i do buy a new truck i will oil it right away
2015 longhorn ecodiesel ,4x4,crewcab ,5.7 bed with rambox,retraxone tonnaeu cover.
Old 04-21-2014, 11:37 PM
pinebeatle's Avatar
Many thanks Sir-- I think I will do this for sure. When drilling holes in door where do you start? and do you do every year or every two years or is one application the norm? Cheers
Old 04-22-2014, 01:00 AM
Baldielox's Avatar
Baldielox Baldielox is offline
Vehicle: 2012 Ram 1500 4x4
Trim Level: Laramie Lonestar
Rep:21
Baldielox is on a distinguished road
I'd get the color you like, you're probably going to have to look at it every day, and do whatever it takes to prevent rust. Krown for one example.
Old 04-22-2014, 09:19 AM
hslager69's Avatar
Trim Level: sxt
Color: red
Drill in the lower portion of the door just above the rounded corner so you will be spraying straight in approx 3-4" above bottom of door,i spray once a year.
