Old 04-20-2014, 09:07 AM
Jabo 13 Jabo 13 is offline
Vehicle: 1997 Dodge Ram
Color: Blue
Jabo 13 is on a distinguished road
Default Starting issues
My problems started after I had my trans replaced. the mechanic damaged the camshaft position sensor and some times it would not crank. I have owned my baby since 98 and she has always fired right up after a half spin on the starter, like clock work. Replaced sensor, no improvement, put another on, nothing. cranks about 50% at that time. new plugs, wires, distro cap & button, and coil, no improvement. codes read oxygen sensor, put both new ones on, code then read torx-converter solenoid???? I changed mechanic. replaced all three sensors on throttle body, new computer, and had it reset. now it fires up first in morning and after a short warm up time, when I shut her down at the store or what-not, she will not restart. nothing seems warm or hot. after about 45 mins to a hour she fires right up????? replaced fuel pump, all relays in fuse box in engine compartment, and after Fathers strong advice another coil, sent him to hang out with original mechanic. codes read both oxygen sensors bad again, just dont believe it. Runs great when she fires up, don't believe its the injectors. any suggestions????
Old 04-20-2014, 12:37 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Stalling after hot and both 02 sensors could indicate a clogged cat. Remove the CAI and peer down inside of the throttle body. If there's oily residue the lower plenum gasket could be leaking. The oil entering the combustion chamber could clog the cat converter and cause premature failure.
Bang on the cat converter with a dead blow hammer a few times to try to break up whatever may be clogging it. Make sure the plenum gasket isn't leaking.
