6 speed to 8 speed conversion? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 04-20-2014, 04:19 PM
huntert's Avatar
huntert huntert is offline
Vehicle: 2009 dodge ram 1500 ST
Color: Austin Tan Pearl
Rep:16
huntert is on a distinguished road
Default 6 speed to 8 speed conversion?
Not sure if this is the right place to start this thread or not sorry in advance if it's in the wrong place. Well pretty much I have 2009 ST 4x4 and I can feel some sort of either tranny slippage or the TC slipping or not locking up. When I graduate in June I'll be coming into some money. I'll probably have to replace or rebuild this tranny eventually (it has 150k+ miles). Would an 8 speed bolt up to place? I imagine that te driveshaft would have to ether be shortened or extended. But also would the transfer case bolt up to the new 8 speed? Also would it honestly even be worth trying to make this conversion, I know the programming would probably be the worst part to deal with. Do you guys think it would be better to just pull the stock trans and just build it up with better frictions, a new valve body, etc? Thanks for any input
Westin black step bars, Diablo intune, 35x12.50x18 Nitto Trail Grapplers, 18x9 -12 offset MAYHEM CHAOS wheels. 2.5 inch dual exhaust with a custom made x-pipe before dual dynomax race bullets, topped off with rectangle tips.
Old 04-20-2014, 05:46 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Even if you could physically make it fit,
it would be nearly impossible to tune your PCM/TCM to make it function properly.
Rebuilding your stock 545RFE would be way less hassle,
and a fraction of the cost.
Old 04-20-2014, 06:07 PM
Rep:2968
I won't say that changing out transmissions would be impossible, but i do believe that it would be very costly because of the programming
Maybe get a performance valve body & torque converter instead
this is something that might want to read
http://www.allpar.com/model/ram/dodg...owertrain.html
more about the transmissions
http://www.allpar.com/mopar/transmissions/545RFE.html
Old 04-20-2014, 08:06 PM
huntert's Avatar
Rep:16
Thank you guys for the input, I had a feeling that the tuning wad going to be the down fall. Is this the appropriate place to discuss transmission? I've been looking all over re forum for more information on the topic. Thank you for the links as well, I'm sure they will be a good read.
Old 04-20-2014, 08:20 PM
Rep:561
Yup,
I just rebuilt my first Trans about 2 weeks ago, replaced several clutch packs
also have a custom built one from L&M customs that's getting fresh OD frictions and filters next weekend.
Good thread here: http://www.ramforumz.com/showthread.php?t=153656
