Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
tonneaucovered.com
Old 04-21-2014, 10:24 AM
acfeldman800 acfeldman800 is offline
Vehicle: 99 Dodge Ram 1500 Ext CabSport
acfeldman800 is on a distinguished road
Default No ac
My AC is not working. Checked fuses and relays they are ok. Clutch can be turned by hand. If the charge is low will that stop the clutch from engaging? Checked the two wire connector that goes to the compressor and there is NO 14v when the switch is turned on?
Old 04-27-2014, 07:31 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
You are correct, the clutch will NOT engage if the "low pressure sensor" says the system is low on charge. You will not get the 12v+ to the clutch if the sensor is not happy with the pressure. You can test the a/c clutch BRIEFLY, by jumping the corresponding #30, and #87 female sockets under the a/c relay. The teminal #"s are usually printed on the bottom of the relay.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
