Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Interior Cleaning and Maintenance!
Interior Cleaning and Maintenance! Keeping the inside clean!
Old 04-23-2014, 08:16 AM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
Default Cleaning seatbelts
What`s the best thing to use to clean my seatbelts? I`ve used armor all cleaning wipes but they don`t work on the stuff rubbed into them. They`re not that dirty, just a build up of ground in dirt/staining from the last 5 years.
Old 04-23-2014, 09:55 AM
rcmpvet's Avatar
rcmpvet rcmpvet is offline
Vehicle: 2014 Ram
Color: Black Gold Pearlcoat
Rep:38
rcmpvet is on a distinguished road
It can be a slow process but here is what works for me; you will need the following:
1 - Hot water
2 - Wet Vac
3 - Depending on soil level you might want to use some upholstery cleaning solution, such as Oxy-Clean Spray or Fantastic.
a - Wet the seat belts with a spray of hot water, practically soaking them.
b - Vacuum them as thorough as you can.
c - Spray your solution (let it soak in to work) or if not too soiled continue with the hot water.
d - Vacuum again.
e - Rinse and repeat as required until they are as clean as you can get them.
If they are really soiled you may have to get someone to help you by spraying on the water/solution while at the same time vacuuming from the opposite side. This will draw the water/solution through the material. Do this again but then reverse the side which gets the water/solution.
You should always try and rinse the solution as best as you can.
There Is No Such Thing As A Stupid Question: HOWEVER: Search Function is Your Friend
Old 05-04-2014, 09:05 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
go to home hardware or home depot and get folex. the best, safest, cheapest, cleaner on the market. spray on, agitate, blot. stain gone.
http://www.homehardware.ca/en/rec/in...8041?Ntt=folex
Old 05-04-2014, 09:27 AM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
letsjet is on a distinguished road
Cleaning seat belts with any liquid is not good. Aircraft seat belts are just usually replaced. Water and cleaning fluids weaken them. A slip on seat belt cover will keep them clean and the cover can be cleaned. It's very tempting to clean them to make them look pretty but they lose tensile strength.
2014 Ram 1500 Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Hemi Orange Pearlcoat
2010 Dodge Challenger R/T Classic Furious Fuchsia 6 spd
Old 05-04-2014, 09:30 AM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
Is this stuff safe for carpets and cloth seats? Headliner?
S S H A D O W
Old 05-04-2014, 09:32 AM
Rep:156
I've never heard of this before. I would think it would take many many many cleanings before that would happen. Think of denim pants (closest thing I can think that compares to seat belt material) - how many times you can wash that before it's weak enough to pull apart...
So, curiosity piqued... Google says to not use hydrocarbon based cleaners.
S S H A D O W
Old 05-04-2014, 10:16 AM
Rep:912
absolutley. it is actually a carpet cleaner.
check it out. it is amazing stuff.
http://www.folexcompany.com/folex-facts/
Old 05-04-2014, 10:56 AM
Rep:156
Thanks!
S S H A D O W
Old 05-04-2014, 11:50 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
I purchased Folex because Primo had recommended it in another post and it is amazing stuff. Purchased a older car that had a couple or cans of Coke left in it over winter and they had exploded spraying pop all over the headliner and seats this stuff cleaned up the headliner easily by spraying on and blotting off. Pretreated the heavily pop soaked areas before shampooing and they came out great. Seat belts are all that is left to do so I will try the method suggested in this thread. Thanks Primo saved me some time and money trying to find something that would work. There was another product called The Real Deal that we used use on campers and it seemed to work better that Folex but is no longer available ?
Old 05-04-2014, 06:41 PM
Rep:912
i cant say im familiar with the real deal.
i like folex because is is safe, non toxic, cheap and seems to work as advertised. glad it helped out in your situation!
