Old 04-24-2014, 08:54 PM
stef0703's Avatar
stef0703 stef0703 is offline
Vehicle: 2010 dodge ram 1500
Color: BLUE
stef0703 is on a distinguished road
Will 2.8 make the front higher? Just wondering what others are doing to run at 2.8?
Old 04-24-2014, 09:06 PM
stef0703's Avatar
Color: BLUE
Macc08 love what you've done with the truck.. How are the exhaust tips holding up with them painted ??
Old 04-24-2014, 09:30 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Originally Posted by stef0703 View Post
I have the rcx 1.75 spacer, what would I run the bilstein at I want level, less take as possible. I sent an email to sales thx.
If you want to use your 1.75" spacer and still be level you'll want Bilsteins at 2.8" Just be careful doing that with the lift. You'll want to make sure your CV and control arm angle aren't too steep when you do it. I typically recommend keeping Bilsteins at 2.1" max with a 6" lift to avoid any issues or a rougher ride.
Old 04-24-2014, 10:21 PM
stef0703's Avatar
Color: BLUE
Thx Brandon.
Old 04-25-2014, 01:39 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
I second this. This is one reason I will probably remove the rear coil spacer, and keep bils at 1.4. less chance of a problem.
Thanks bud! The tips are holding up great! I roughed them up a bit with some scotch brite before hand, and the tremclad really holds well. I've used it a few times and I have yet to be disappointed.
Old 04-25-2014, 12:05 PM
stef0703's Avatar
Color: BLUE
The chrome tips took a beating from the salt this winter. This might be a solution..
