Old 04-26-2014, 11:46 PM
rumfoot rumfoot is offline
Vehicle: 1996 dodge ram 1500 5.9L
Trim Level: SLT Laramie
Color: red
rumfoot is on a distinguished road
Default pressure bleeding brakes
hi everyone,
I have a 1996 dodge ram 1500 5.9 liter and the brake pedal is mushy. i have a lot of bubbles in the new master cylinder rear reservoir. I'm thinking about doing a pressure bleed on the brakes. Are their any cons to doing this? Should the engine be running while i do this? Does the brake pedal have to be in any certain position while i bleed the wheel cylinders and calipers? Any advice will be appreciated. The pressure system I will be using will push new fluid from the master cylinder to the combination and RWAL valves to the wheel cylinders. How much fluid will i need to do the flush?
Rumfoot
Old 04-26-2014, 11:56 PM
Rep:2657
check out these videos, 1 or 2 of them will work for you
also check out the ABS brake system bleeding
https://www.youtube.com/results?sear...am+brakes+1996
Old 04-27-2014, 07:35 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Never did the pressure-bleed. Only the vacuum bleed. But the pressure bleed is listed in the Factory manual as a service procedure. So no cons that I can see. Thanks for the link Yankee.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 04-29-2014, 10:49 PM
Color: red
Watched the you tube videos. It looks simple enough. Thank you for the help
Old 05-01-2014, 07:39 PM
Mainewoodshunter Mainewoodshunter is offline
Mainewoodshunter is on a distinguished road
Hope you have better luck than I've had. I had some bad lines in the rear so I replaced the line and cylinders. I bled them like six times now and flushed with new fluid. I don't get a brake light or abs light anymore but ever since I hooked the rears back up my brake pedal goes to the floor and is soft.
