Old 05-06-2014, 03:17 PM
Hemi1500 Hemi1500 is offline
Vehicle: 2011 Ram 1500
Trim Level: SLT Big Horn
Hemi1500 is on a distinguished road
Ncrefasi, that sounds slightly different. When mine acts up I always get the light. The strange part is that, at least lately, it always seems to engage properly when I select 4WD AUTO or 4wd LOCK myself.
I asked the tech to check for corrosion or water intrusion in the connectors. It always seems to happen when the roads are wet. Also, I washed the truck on Saturday morning, and Saturday afternoon it acted up worse than ever, light stayed on for a good 5 miles or so before going off. I wonder if moisture is getting into the FAD connector or the TC shift motor connector and causing an intermittent short...?
Old 05-07-2014, 03:57 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
are you still under warranty?
Old 05-07-2014, 04:27 PM
I just bought it 2 weeks ago, so it's still under the dealership's 30-day 100% covered used vehicle warranty, plus it's CPO so I have the balance of 7 year/100,000 miles.
The dealer has had the truck since Monday and has been trying to find the culprit to little avail. They have poked, prodded, scanned, road tested, etc. The wiring is sound, the contacts are clean and dry, the TIPM is functioning perfectly and has no stored codes. The shift motor, mode sensor, and FAD are functioning exactly as they should. They are leaning toward a bad selector switch; I'm told there were some bad ones with deficient solder joints on the board on the back of the switch that have caused similar problems. So they ordered a new switch and hope to swap that out tomorrow. We'll see, I hope it's something simple like that!
At least this time the loaner is a brandy-new 2014 Hemi CC.
Old 05-08-2014, 02:49 PM
Default It FINALLY freaked out for the tech!!
I was all set to pick the truck up and wait for the call that he switch arrived, when the tech spoke up. For 3 days he had the truck, it didn't happen, then this morning it suddenly decided to flash "4WD AUTO" on its own. He witnessed it go through all the modes: 4WD AUTO, 4WD HI (or LOCK), flash 4WD LO, all by itself, then finally it reset itself back to 2WD. Needless to say, I left it with them for another day for further troubleshooting.
Could this be the TCCM perhaps? And what role does the IC play in this?
Old 05-09-2014, 03:59 PM
Default Spending the weekend without the truck...
They're narrowing it down. The prime suspect is the TC shift motor but they want to do more diagnosis to be sure. Sucks being without my new baby, but I'm pleased that they seem to want to get it right and not just throw parts at it.
Old 05-12-2014, 04:05 PM
Angry Another week without the truck
A new encoder motor is on order, meanwhile I'm told I can take the truck and bring it back when the part comes in.
But when I went to drive away it felt like it was stuck in 4 LOW! Front axle locked, noisy as heck, gear whine up the yin-yang. "4LOW" is blinking all the time. Move the knob all the way to 4LOW, comes on solid; move to any other position, that position's indicator and 4LOW blink. No matter what, it will NOT come out of 4LOW. I think the encoder finally decided to give up the ghost.
So I got the loaner for another week until the part comes in. I sure hope that fixes it! I put more miles on this loaner than my own vehicle since I bought it.
Old 05-12-2014, 07:05 PM
Trim Level: sport
Color: green
Rep:657
sounds like the dealer is doing their part. hang in there.
Old 05-12-2014, 07:26 PM
The dealer has been working very hard on this thing and I have absolutely no issue with the level of service I have been getting so far. Simply impressive.
I'm very concerned about the loud growl coming from the drivetrain currently. I hope this doesn't turn into a major replacement, like needing a new TC or front axle or something. But the fact that they are taking the time to do this right speaks volumes, seeing that they're not making a red cent from me off this repair. They might get warranty reimbursement for parts, but they're eating the labor right now, and there have been many hours spent on this issue so far.
But I DO miss my truck, even though I only bought it 2-1/2 weeks ago and have only driven it for 5 days!
Old 05-14-2014, 08:44 AM
endlive endlive is offline
Vehicle: 2011 Ram 1500 Crew Cab
Color: Hunter Green Pearl
Rep:86
endlive will become famous soon enough
Good, let them eat the labor costs, you only had the thing for 2 weeks!!
Old 05-14-2014, 12:46 PM
Picked the truck up today, and so far so good. They replaced the encoder motor and the dashboard switch. It's only been driven 10 miles but everything appears to be fine.
I had the other thread going about the howling noise, but that's completely gone now. Apparently the encoder finally bit the dust and stuck part way to 4LO. Now it's smooth & quiet like it should be.
I took the tech for a ride before I left just to make sure everything was copacetic. If after a week it's still behaving itself then I'll consider this resolved.
