Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 04-30-2014, 02:12 PM
bigcile bigcile is offline
Vehicle: 1991 Dodge Ram D250
Trim Level: Base
Color: Blue
bigcile is on a distinguished road
Default 1991 D250 Speedometer Problem
I will say up front I am sorry if this thread already exists, but I could mot find it by searching. I have a '91 D250 and my speedometer does not work. I was told by the previous owner that it worked before I test drove it, but I am not sure. I have already replaced the speed sensor on the transmission, and it did nothing. Does anyone have any ideas on what it could be or where I may obtain another gauge cluster? I have called salvage yards all over the country and have had no luck so far. Any help would be greatly appreciated.
Old 04-30-2014, 02:19 PM
KevenP's Avatar
KevenP KevenP is offline
Vehicle: 90 D150/90 D250
Rep:19
KevenP is on a distinguished road
I have a gauge cluster out of a '90 that I guarantee works.
The gauges have white faces.
Did you check to see if the plug is still attached to the back of the cluster?
Do the other gauges work?
2Cor13:14
Old 04-30-2014, 05:50 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Sounds like the speedo head. I've had that issue with my '90 and the choices are: use another 20+ year old cluster, send one off for restoration, get a new speedo head and do yourself, make your own dash with new gauges, or the quickie (a cheap GPS).
Old 04-30-2014, 07:28 PM
Trim Level: Base
Color: Blue
Yes, the plug is still attached.
Old 04-30-2014, 11:07 PM
Rep:85
http://www.dnaspeedometers.com/dod.htm
seems to be involved in this sort of repair.
Old 05-01-2014, 11:48 AM
KevenP's Avatar
Rep:19
Good to know Gen1dak. Thanks for the link!!
2Cor13:14
Old 05-01-2014, 03:03 PM
KevenP's Avatar
Rep:19
PM me you are interested in another cluster.
2Cor13:14
