Old 05-02-2014, 04:39 PM
Ballgame Ballgame is offline
Vehicle: 2000 dodge ram 1500 4x4
Color: Green
Ballgame is on a distinguished road
Default Multi symptom electrical issue.
2000 1500 4x4. When turn on headlight switch, right turn signal indicator lights-on dash--no right front marker light on. Bulb is good- already replaced. Also when push horn it does not work, but lights right turn signal indicator, and right marker light comes on. Push horn and switch turn signal to right and both elements of bulb light. Right turn signal front and back work but blinks very fast like a bad bulb. Help!!!!!!!!!! I have whole dash torn out and have searched all accessible wire harnesses. All this started when driving, turning right with signal on and honked horn.
Old 05-02-2014, 11:02 PM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2939
You've got a serious short somewhere. I know that's no help and they are a PITA to track down.
Old 05-03-2014, 12:26 PM
Color: Green
thanks for the response. actually not a short but loss of ground in circuit. power going out to junction plug JC3--(located on frame rail - right side under head lights and horn mounting position) and backfeeding/bleeding off voltage out to all components horn, marker light/turn signal bulb and indicator on dash, being fed from plug. cut off 3 of 4 blacks---(grounds) tied back together with another wire and grounded all to frame. works like a charm!!!! Green monster back on the road..
Old 05-03-2014, 11:05 PM
Rep:2939
Voonderbar! Thanks for the update, Jon. And very impressed that you found it. Nice job!
Old 05-06-2014, 10:30 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Congrats! I'm an electrician. For most of the problems in DC, I say, "If it don't work, check power. If it works weird, check grounds." Good for you in finding this!
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
