A/C Clutch not Kicking in - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-03-2014, 03:21 PM
dacdog dacdog is offline
Vehicle: 2009 RAM 1500
Trim Level: Crew Cab Lone Star
dacdog is on a distinguished road
Default A/C Clutch not Kicking in
Noticed today the A/C was blowing hot air. The A/C clutch never tries to kick in. I tried the battery disconnect game to no avail. Fuses appear all good. Any suggestions?
Old 05-03-2014, 11:41 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Have you checked the pressure of the R134a in the system? You could have a leak and the low pressure sensor isn't letting the compressor kick on.
Old 05-04-2014, 07:49 PM
Roger,
Thanks for the tip. Was low on 134-a recharged and working great now. Used Stop Leak, hopefully it does!
Old 05-05-2014, 02:47 PM
Rep:2968
Voonderbar! You're welcome, and thanks for the update.
Old 05-14-2014, 12:09 PM
So the stop leak didn't stop leak. Is there a common area of leakage? Has anyone used liquid gas leak detector to find, does it work? Other suggestions?
Old 05-14-2014, 01:56 PM
Rep:2968
I always used a dye and then a black light to see where it's coming out.
Old 05-14-2014, 02:07 PM
So does that come in a pressurized can, like the 134? I looked and couldn't find anything like that.
Old 05-14-2014, 04:20 PM
Rep:2968
The one I used came in syringe with a zerk fitting on the end so I could force the dye in the system.
