Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 05-04-2014, 07:23 PM
evergreen evergreen is offline
Vehicle: 2001 Dodge 2500
Trim Level: Laramie SLT
Color: garnet
evergreen is on a distinguished road
Default 2001 bump steer and wandering dilema
I am having a hard time identifying my steering problems. Put my 01 with 250,000 miles in the ditch, enough damage to replace the whole front axle assembly with a used unit from a truck with 90,000. New ball joints, track bar, OEM steering box, front shocks, complete brakes, tires, alignment...reset caster twice. Have had it to three different shops...same result at each "sorry". I needed a new steering box before the accident but it never had the bump steer problem at all or a problem centering. I was told possibly tight ball joints so give it a few miles...2,000 miles later no change. This is still a great truck, I need to figure this out so my wife will drive it again...my dog won't even ride with me anymore! Sorry this is so long...shorter than the ongoing problem though...
Old 05-06-2014, 10:48 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Please describe your "bump-steer" problems in more detail.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 05-09-2014, 11:47 AM
Color: garnet
Dips and bumps in the road cause the steering wheel to jerk to about 2 o'clock but it does recenter. I remembered the problem existed before I had the ball joints replaced so possibly something else. I found yesterday that the shop that replaced the shocks on the front used a Monroe gas...too light for my truck as I believe the ride is a bit softer than it used to be and the spring travel is greater I think. Maybe a tougher shock? I am also going to check the lower steering column bearing. I did need a new steering box before I put it in the ditch, but it just had loose steering and with the new OEM box I should not have that now though not as bad. Not sure if this is one thing or a couple of related issues. Thanks
bump steer, steering wander
