Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Body & Interior
Old 05-06-2014, 03:06 AM
benramos benramos is offline
Vehicle: 2011 Ram 1500
Trim Level: SLT/Big Horn
Color: Brilliant Black Crystal Pearlcoat
benramos is on a distinguished road
Default Someone sanded my dashboard
The previous owner of my Ram must have had something fairly large and rough sitting in the front passenger floor that rubbed against the lower dash. Instead of being textured and smooth its as if someone took sandpaper too it - most of the texture is still there but it's very rough and catches/collects fabric fuzz/fibers if your pants rub against it and transfers a dark smudge/grit to the fabric.
I initially thought it was residue of some sort and tried using a wet cloth to clean it off (no cleansers, just water). While I did get it cleaner, it pretty quickly became apparent that the surface itself was abraded.
Are there any products that anyone would recommend that would coat/seal the surface to smooth it out and prevent it from catching on and transferring smudge to clothing?
Thanks!
Old 05-06-2014, 03:27 AM
Rep:2705
I once saw a tv show about fixing up a car for profit
sorry i don't recall the name of it
They had worked on the dash, i believe to install a speaker system
They ran across a similar issue with the epoxy & paint not sticking correctly
I will continue to think about the name of the show ....
Old 05-06-2014, 03:59 AM
Rep:2705
I believe that the texture was done by using Grain Paper originally
it is the adhesive that holds on the grain paper that is causing your stains
maybe this will help you some how
http://www.haywoodproducts.com/catal...age=page&id=30
Old 05-06-2014, 04:22 AM
I'll give it a look. Thanks!
Old 05-06-2014, 09:37 AM
tguil tguil is offline
Vehicle: 2012 Ram
Trim Level: Big Horn Quad Cab
Rep:45
tguil is on a distinguished road
I suggest taking your truck to good detail shop to see if they can get the residue off and then call it good. You very easily could make it a lot worse. The dash on our Rams scratches very easily. I put a small scuff in my lower glove box door and was going to replace it..quite pricey…until a put a second set of scuffs in the door with the soft edge of a cardboard box. Now I just don't look over at it…a cheap fix.
2012 White Hemi 1500 QC, 4X4, Big Horn Edition, Protection Group, Luxury Group, 3.92 Anti-Spin, Mopar Bedliner, Mopar Tubular Side Steps, Mopar Molded Mud Guards, Access Roll Up Tonneau, Michelin LTX AT 2's
Old 05-06-2014, 08:08 PM
Probably a good idea - I for sure don't want to add to the issue. Thanks!
