How much Freon - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 05-06-2014, 05:30 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
Default How much Freon
I thought there was suppose to be sticker that told me how much freon my 04 hemi holds...but it does not seem to be present. Anybody know what 'full' is on my a/c system? greatly appreciate the assistance.
Old 05-15-2014, 05:40 AM
Color: Gray
Default a/c issues
So I am having trouble with my a/c system short cycling and not cooling properly at idle or a stop. Most people have told me the first thing to check is freon as its the simplest fix. I have googled how much freon should be in my system and received conflicting reports. Anyone have a number for lbs of freon?
Old 05-15-2014, 12:34 PM
Ewag2983 Ewag2983 is offline
Vehicle: 05 Ram 2500
Color: Blue
Ewag2983 is on a distinguished road
Don't worry about how much in pounds. Get an r134a manifold and check your pressures. Low side should be around 30, high around 240.
Old 05-15-2014, 02:01 PM
Color: Gray
Thanks!!
Old 05-30-2014, 03:16 PM
Color: Gray
This is going to sound dumb you are talking PSI, correct? my gauge only goes to 150, so I guess I need a better gauge as its showing the needle is barried at 150psi, but still not cooling at idle.
Old 05-30-2014, 09:38 PM
Color: Blue
You sure you got an r134a gauge set? Or are you using like a recharge kit that's on low side only?
Old 05-31-2014, 06:31 AM
Color: Gray
Its a recharge kit with a gauge; I didn't look at it before when we were posting to discover that it only goes to 150; I will go get a stand alone gauge.
Old 06-03-2014, 03:29 PM
ucanthngwme ucanthngwme is offline
Vehicle: 08
Rep:12
ucanthngwme is on a distinguished road
The pressure is going to read different values depending on the outside temperature. What may be a "normal" pressure for someone in Maine is certainly not going to be the same as here in this Hell known as Texas!
There are "charts" that show the different readings for different outside temperatures.
Old 06-05-2014, 04:44 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
with a compressor short cycling first thing i'd check is to make sure the condensor fan is running while the AC is on. if that's not running check the fuse and swap the a/c relay with another one in the box. if the fuse is good, swapped the relay and the condenser fan still isn't running it's the fan motor. They are very common I've done two already in two different 3rd gen rams.
Old 09-03-2014, 10:38 PM
chrisbrn2000 chrisbrn2000 is offline
Vehicle: 2003 Dodge Ram 1500
Color: pewter Gray
chrisbrn2000 is on a distinguished road
1 pound 10 oz (0.728kg)
26oz in other words
