Old 05-14-2014, 12:32 AM
vyper340 vyper340 is offline
Vehicle: 2014 Ram 1550 Longhorn Limited
Trim Level: Longhorn Limited
vyper340 is on a distinguished road
Vararam!
Old 05-14-2014, 01:30 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
varaam
Old 05-14-2014, 09:31 AM
dleininger's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Laramie QC
Color: Blue Streak Pearlcoat
Rep:25
^^Oops, I think you cropped out the intake? Half covers are bad ass tho.
Old 05-14-2014, 08:55 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I tried just about all of them before finally switching to the Ultimate CAI
inter-cooled 500WHP
plus a little Alcohol Injection...(60/40 Water/Meth) to drop intake air charge temps even more
Old 05-15-2014, 10:40 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
I love the air raid!
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 05-21-2014, 08:15 AM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
vararam all day long, my reasoning is different than others tho. I was very impressed with how quite the truck ran with it. Personally I am not a huge fan of making the cab volume too loud (unless it is the whine of a supercharger!). I have one for sale as I am in the middle of a RIPP kit install. If you interested PM me, my Vararam has less than 10K miles, looking to get 250 for it.
Mods: Lowered and Blown.
Old 05-22-2014, 06:13 PM
Piston Slap's Avatar
Piston Slap Piston Slap is offline
Rep:42
Piston Slap is on a distinguished road
Originally Posted by JETsimple View Post
Vararam is claiming 30HP and 30+ FT/lbs. of torque with this intake with no tuning. Is that realistic for a CAI?
No. Not 30hp. Someone I know with a L99 Camaro picked up 10rwhp and Moe's reportedly got 16rwhp on a truck that had several mods.
Old 05-22-2014, 06:36 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Originally Posted by HemiLonestar View Post
Niiiice. I was thinking about using a 4th gen Vararam to mate up with my SRT hood to pull air through the hood, just for coolness factor.
The Vararam is great, but you will be disappointed, I think with the effectiveness of the hood scoop. If you could measure air flow, I think you'll find air actually flows out of the hood scoop. The Ramchargers did a lot of research back in the 50's and 60's and found that you had to be several inches above the hood to get ram air effect. You will get better results, just using the Vararam as designed. I have the "Vararam hemi under glass" on my 05, it is true ram air. Coolness factor, will be great, though!
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 05-23-2014, 10:46 AM
SiriusBlack's Avatar
SiriusBlack SiriusBlack is offline
Vehicle: 2014
Trim Level: Black Express
SiriusBlack is on a distinguished road
SO the Vararam will NOT work on a truck that does not have vented hoods?
Old 05-23-2014, 01:11 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
That is not what Hydrex was trying to say, The vararam was designed, as far as i can tell, to pull the air that comes through the grille at the speed you are driving, and push it into the big filter element on top of the engine.
What hyrex was trying to say, correct me if im wrong, is that where the hood and grille meet causes turbulent air flow which is making the area on top of the hood a low pressure system. basically right on top of the hood is a pillow of air that is creating a nice transition for the air coming into the truck to change direction and go over the cab, inturn this makes the the scoops that sit right on the hood useless for a "Ram Air" application because instead of forcing air into them the are sucking the air out of the engine compartment. Making them more of a cooling vent than a ram air vent
