Old 05-24-2014, 06:15 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
The Gen3 Vararam was true ram air through the bumper insert but quality and fitment were poor, you need a high pressure area for true ram air. Even the SRT10 Ram hood scoop is not for ram air its for heat to come out. Check out the new Hellcat Challenger and see what SRT did for ram air for the SC6.2 Hemi.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 05-25-2014, 03:32 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
x2
I use Dual 4" feeder tubes to feed my supercharger
after removing the lower bumper cowl insert
Old 05-30-2014, 11:21 AM
HammerHead's Avatar
HammerHead HammerHead is offline
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
Originally Posted by karposvt View Post
Not an issue for me...Texas!
Me either, in Georgia. But what about rain water?????????
Geared and Tuned (Greene Racing Motivation) 14.0@96
Proud member of the 4 second club...
Old 05-30-2014, 11:24 AM
HammerHead's Avatar
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
x2
Any problem with rain water with your setup or the Vararam?
Old 05-30-2014, 11:24 PM
Rep:554
I have never owned a Vararam,
and it's not possible for any outside water source to enter my system,
and even if it did I would have no concern.
I actually spray water/meth directly into my intake intentionally when boost hits 4-8 psi.
250 psi pump to a dual jet setup into my charge tube...
The benefits from a simple water injection are so remarkable it’s hard now to imagine running a supercharged or turbocharged system without one. Regardless, if it’s equipped with an intercooler already. Below is a summery of these benefits.
  • Reduces air charge temperatures by 50-150+ degrees
  • Reduces cylinder temperatures by up to 300+ degrees
  • Increases your 87-93 octane pump gas by 8-20+ points
  • Allows you to safely run more boost and timing
  • Longer more stable combustion expansion and progression
  • Removes carbon build-up from combustion chambers, pistons and valves
  • Reduces and helps eliminate engine damaging detonation and pre-ignition
  • No need for expensive racing fuel or additives
Source: http://www.alcoholinjectionsystems.com/
(and no, its not much use to non-boost applications )
Old 05-31-2014, 12:00 AM
Giants89's Avatar
Giants89 Giants89 is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX 4
Color: Blue
Rep:48
Giants89 is on a distinguished road
Does anyone have any positives thoughts on the S&B intake? I' am looking into purchasing one..
DPF Deleted_H&S performance EGR Delete_5" turbo back exhaust_RaceMe tuned_35x12.5 Nitto's_Recon Tails & 3rd Brake light.
Old 05-31-2014, 04:33 PM
db1 db1 is offline
Vehicle: 2010 dodge ram
Trim Level: sport
Color: mineral grey
db1 is on a distinguished road
i did a volant. love it. the vararam looks really nice too.
DOSNT ROLE ON TEENAGE RIMS!
Volant cai , bt catch can,180 stat, Moes 85mm, Sonnex line booster, Superchip programmer Tranny upgrade , Bilstein shocks 25% stiffer springs, Air bags, 22" srt10 replicas matt black, magnaflow tru x muffler.
Old 05-31-2014, 05:24 PM
HammerHead's Avatar
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
That is an awesome setup. I see you have the stock manifold; nice to know it can withstand 500+ HP.
Old 06-01-2014, 12:44 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
The varram works great i drive through pouring rain all the time and the intake has never been wet and as far as the air bubble ive noticed better throttle response with it the hood acts as a seal for the intake it works quite well
dodgert's Avatar
Trim Level: rt
Rep:1061
to bad the tranny cant lol
