98 Ram 1500 5.9L Electrical Nightmare - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 05-07-2014, 12:04 AM
giebner1 giebner1 is offline
Vehicle: 1998 Dodge Ram
Trim Level: St
giebner1 is on a distinguished road
Angry 98 Ram 1500 5.9L Electrical Nightmare
So I recently did a tune-up, replacing distributor, rotor, plugs and wires, and eventually the coil, ASD relay and crank sensor. Finally got the truck running again after 5 days of beating my head - turns out replacement distributor caps are rotated 180 degrees from OEM. Truck was running great. Then this weekend I was driving it when it just shut off. A guy stopped and pulled me off the road and was looking at it with me. I told him how I had just replaced the ignition system and he said it sounded like the ECM or PCM in this case. So I had it towed, verified there was no spark, and disconnected the battery touched the positive and negative wires together and let it sit disconnected for about 15 minutes. Reconnected the battery and it fired right up. Today I was sitting in my truck with it running for about 10-15 minutes and it just shut off again. This time luckily it fired right back up. Tonight I went to pull it out of the garage to wash it and it cranked but wouldn't start. I tried the trick that worked the last time by disconnecting the battery and touching the wires together and letting it sit at least 15 minutes but it still won't start. I tried this twice and no change. I am thinking I need a new PCM but figured I would see if anyone has any other ideas before I drop another $200 into this growing pit of money that the truck has turned out to be.
Old 05-07-2014, 02:26 PM
Saltillo Express's Avatar
Saltillo Express Saltillo Express is offline
Vehicle: 1998 Dakota RT 178K miles
Saltillo Express is on a distinguished road
If it's a bad PCM or dropping the PCM link it will set a code for that. Scan it for codes.
Chance
Old 05-09-2014, 10:29 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Good advice Saltillo. Scan this thing, and see where we are really at. No BUS, or other communication errors are a sign of a bad ECU.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
computer, electrical problems, pcm
