Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-07-2014, 10:59 PM
atknut atknut is offline
Vehicle: 2004 Dodge Ram
atknut is on a distinguished road
Default Stuck on defrost
Hi there, is there a "hall of wisdom" list of top 10 things to check for a heater stuck on defrost for a 1997 ram?
Thanks.
Old 05-08-2014, 10:03 AM
tomcatg tomcatg is offline
Vehicle: 1998 Dodge Ram 4x4 Sport
tomcatg is on a distinguished road
Possibly blend door broken?
Old 05-09-2014, 10:40 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
That, or a vacuum failure/leak. The "default" position is "defrost" in case of loss of vacuum. Safety feature to keep the windshield clear. Yes, you may freeze and die, but at least you will be able to see the road.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 05-09-2014, 11:08 PM
Hmmm...thanks for the response guys. I also notice a faint whiff of that sweet smell coming from the defrost. Maybe a slight "weep" in the heater core? What's the best way to check? Pressure test?
Someone suggested bars-leak to me, but I ran the other way....
Old 05-10-2014, 11:30 PM
Rep:194
Check for dampness in the carpet. Use a radiator pressure tester and look for pressure loss. But it seems that sickly-sweet odor is your best clue.
Old 05-12-2014, 10:22 AM
Thanks...no carpet. I have vinyl floors. No evidence of leakage either. Someone suggested to melt a small hole in the bottom of where the core is to look. It may be evaporating as fast as it's leaking?
Old 05-13-2014, 10:23 PM
Rep:194
If the smell is there, then it is a leak, and it is inside. You are in denial. It is an all-day crap job that pegs the "Suck-O-Meter" at 9.9.
