Old 05-09-2014, 03:14 PM
nboake23 nboake23 is offline
Vehicle: 2013
Trim Level: Outdoorsman
Color: True Blue Pearlecent
nboake23 is on a distinguished road
Default Gear Information?
I'm fairly new to The truck scene and I keep seeing people talking about "gears" and swapping gears and such, and I honestly have no idea to which they are discussing. I'm wondering if anyone could give me a rundown of swapping gears or attach a link I could read so I understand what its all about?
Old 05-09-2014, 06:14 PM
cvieke's Avatar
cvieke cvieke is offline
Vehicle: 2008 Ram
Trim Level: TRX
cvieke is on a distinguished road
Referring to the ring and pinion gear(s). My factory rear end gear was 3:55, I have a 2wd, I am running 35" tires. With the factory rear end gear the truck was a little sluggish on take off, I swapped out the factory 3:55 and went to 4:56 gear. Helped take off a lot., only downside is worse gas mileage.
Volant CAI, Magnaflow muffler, 2" leveling, 3" body lift, Bushwacker fender flares, 4.56 gears
Old 05-09-2014, 10:00 PM
Vehicle: 2013
so is it recommended if I were to upgrade my tire size?
Old 05-09-2014, 10:30 PM
cvieke's Avatar
Vehicle: 2008 Ram
Trim Level: TRX
That all depends, I wanted better performance out of my truck with the larger tires. Performance wasn't bad. I just wanted more. If you go to larger tires, see what you think first. It took me about a year before I decided to swap out the gear. Is your truck 4 WD? If so it can get expensive since you will have to do the front end gears also. Also if you do much towing with larger tires, swamping out the gears woulld be helpfull.
Old 05-09-2014, 11:30 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2823
gearing can be confusing in many ways
on flat ground driving, say at 55 mph
your engine & transmission & therefore the drive shaft are all turning the same number of rotations.
If the engine is turning 1500 revolutions per minute, (RPM). so is the drive shaft & the shaft of the Pinion gear.
The other end of the Pinion Gear shaft has a geared head on it & it engages the Ring Gear
without going into a boring bunch of detail
The Ring Gear then rotates much slower then the drive shaft, because of its larger diameter
The Ring Gear basically make 4 smaller gears turn & they in turn cause the 2 axles that the wheels & tires are connected to rotate, the wheels & tires, although no one much thinks of them as gears, they definitely are smooth gears
This sort of explains it best
our trucks have several different gearing options
3.21 slow take off, great gas mileage
3.55 slightly faster take off, you maybe lose a bit of mileage per gallon, but you gain some power or torque
3.92 yet again faster take off, again more added torque, more loss in MPG
4.11 quicker take off, more torque yet again, gas mileage is starting to suck
Now if you go to taller rear tires, like from 32" to 35", no matter what option you have, you are changing your gear ratio even further
at some point your engine is turning 3,000 rpm or more to do the original 55 MPH
Have i confused you enough ??
Old 05-10-2014, 12:36 AM
Vehicle: 2013
that's perfect thank you I can wrap my head around this easily enough
Old 05-11-2014, 11:15 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
think of a 10 spreed bike...the lower the gear the more distance you get with each pedal rotation..great and economical on flat land or down hill...but once going up a grade you tend to change the gears to use less effort. same concept here..I use to run 4.56's on a 30" tall tire and loved it, could roast tires most easily
Old 05-12-2014, 01:40 PM
HemiLonestar's Avatar
Rep:289
All about the mechanical advantage, makes it easier to get that big hunk of metal moving.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red" (Mods list in profile)
2006 Charger R/T "Little Red"
Old 05-12-2014, 01:58 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
One small correction, with an overdrive in the transmission in top gear the engine and the driveshaft are not turning the same speed, the engine is turning slower. Before overdrives became problem 4th gear in a stick and 3rd gear in an automatic was a 1:1 ratio so they would have been turning the same speed.
Old 05-24-2014, 08:02 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
moes performance 4.56 gears for 4x4 u need front and rear and timkin
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
