Old 05-11-2014, 11:23 PM
Steve8522 Steve8522 is offline
Vehicle: 2013 Ram 1500 Laramie
Trim Level: Lamarie
Color: Maximum Steel
Steve8522 is on a distinguished road
Default Mopar Catback - drone issue
Hello everyone! I purchased my 2013 Ram 1500 Laramie in October of last year and I truly love the truck. I have several mods as you can see from my list. My biggest concern right now is an issue I'm having with my mopar catback. I love how it sounds when I get on the throttle, how it sounds at startup, and all that fun stuff. However, today I went on my first trip since having the catback installed in which speeds we regularly at or above 70mph and I noticed a severe drone in the cabin. Even when I was just cruising without accelerating it almost sounded as loud as if I was accelerating. This is my first exhaust system of this caliber and I'm not sure if this is normal but I felt like it was pretty bad. What are the solutions? I've been trying to look around and see what people have to say on the forum but it is hard to search through so many threads with other things being talked about in them. Here's what I've come across so far: use a mufflex drone suppression pipe, have the stock resonators put back on (I still have the original exhaust), turn of MDS for which I would need tuner and that would more than likely void my warranty. I want to keep that beautiful deep throaty sound because that was the whole point of the mod but lose the drone or at least reign it in because it was pretty bad. What is my best option here?
Old 05-12-2014, 11:06 AM
Saltillo Express's Avatar
Saltillo Express Saltillo Express is offline
Vehicle: 1998 Dakota RT 178K miles
Saltillo Express is on a distinguished road
I tried a couple single in dual out mufflers on mine and it droned like a dog. I swapped the original bus muffler back on until I can go true duals. I personally think the 2 into 1 stock set up is problematic for drone when adding an aftermarket muffler. (personally, my opinion). The single 3 inch pipe is a joke. What's that 1.5" per side?
I am not convinced that the downstream resonators make that much of a difference. I mean sure, they do. But do they? I think the source of the drone is that single 3' pipe. That's why that bus muffler is needed to quiet it down.
Not the answer you were looking for. Just wanted to comment.
Chance
Old 05-12-2014, 11:22 AM
Murphy2 Murphy2 is offline
Vehicle: 2010 Dodge Ram Quad Cab 4x4
Murphy2 is on a distinguished road
You dont need a tuner to turn off the MDS. Manually shift into 5th and you are good to go, no more drone.
Old 05-12-2014, 12:20 PM
Trim Level: Lamarie
I have the 8-speed trans. I'm not sure how to manually set the gear it is in. Any thoughts on that? The drone was terrible at or above 70 MPH when at 2000RPM or greater.
Old 05-26-2014, 11:03 AM
Its still doable, done with the gear- or gear+ buttons on your steering wheel. Turn the dial to D, hit the gear- to get into 1st, then gear+ until you get to 8th. Just leave it in 8th while you drive and no drone.
Old 05-26-2014, 08:49 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
you need a muffler with an 11" width body to get rid of drone...I've used several different maggies and I found when I went with their big 5 x 11 x 22 muffler, the drone went away..the 8" and 9" width mufflers will drone no matter what length you get.
Old 06-05-2014, 06:29 PM
Ram11's Avatar
Ram11 Ram11 is offline
Now 2012
Vehicle: 2012 Dodge Ram 1500
Color: Deep Red Pearl
Rep:146
Ram11 will become famous soon enoughRam11 will become famous soon enough
Wow thats odd mine has none at all ,,,do you have a 6 or 8 speed tranny
Factory Fender Flare's... Smoked Rain Guard's... 8,000 Hid'... Zeta Body Side Molding... Painted Pinstripe... Dodge S/S Door Sills... S10 Bed Slide... Ghost Flames... Mopar Tonneau Cover... Mopar High Performance Exhaust... K and N Cold Air Intake...Bilstein 4600 Front Shocks.....Thunder Form enclosure Loaded with 2 10 Kenwood Subs,,
drone, exhaust, mopar catback
