Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-12-2014, 07:46 PM
larrysram3500 larrysram3500 is offline
Vehicle: 2003 dodge ram 3500
Trim Level: laramie
larrysram3500 is on a distinguished road
Angry Bad vibrations at 55 to 65 mph
MY RAM 3500 DUALLY HAS A VIBRATION AT 55 TO 65 MPH I REMOVED AUTOMATIC TRANS , HAD IT REBUILT ...NO HELP I HAD NEW INPUT AND OUTPUT BEARINGS INSTALLED IN TRANSFERCASE , NO HELP ...REMOVED BOTH DRIVELINES AND UNDER NO LOAD 1500 T0 1700 THE VIBRATION IS THERE.....IN PARK AT THESE RPM NO VIBRATION .... HELP
Old 05-13-2014, 05:59 AM
thunderhawk's Avatar
thunderhawk thunderhawk is offline
Vehicle: 2005 Dodge Ram 1500 QC
Rep:6
thunderhawk is an unknown quantity at this point
have you had the rear tires checked to see if they are out of balance Tire Could just be out or If Someone has Installed Balance beads inside the tires they tend to after awhile if they get moisture on them can Bunch up in tire at Certain Speeds
Old 05-14-2014, 03:43 PM
Trim Level: laramie
Default bad vibrations
YES WE CHECKED TIRES WE REMOVED BOTH DRIVELINES AND THE VIBRATION IS THERE AT 1500 RPM IN GEAR BUT GONE IN PARK AT 1500 RPM...STARTING TO THINK MAYBE THE FLEXPLATE IS CRACKED, IT DOES HAVE A HEAVY BANKS BILLET CONVERTER....
