Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 05-13-2014, 05:18 PM
mookiex4 mookiex4 is offline
Vehicle: 1998 Dodge Ram 1500
mookiex4 is on a distinguished road
Question I need assistance with a 7 blade towing plug please.
Hi all,
I have a 98 Ram 1500 4x4 Sport and it had the plug under the dash for the electric brake controller. 4 wire. In the engine compartment there is a Trailer fuse relay, (Not sure if it is blown and do not know how to test it.).
I installed the brake controller and plugged in the trailer connection without hitching it to the truck. I have everything except the Electric brakes. It is not connecting to the trailer. Does it have to be hitched?
When i got underneath it I found out the previous owner had U-Haul do their hack job on it. After I unraveled a roll of electrical tape I saw that the white and black wires were not connected. They were just folded over in the electrical tape.
I need to know the following:
1. Does the trailer have to be grounded to the truck through the ball and receiver of the truck?
2. If the trailer relay fuse is blown will that affect the electric brakes? If it is, then how do I test it?
3. Do the black and white wires have to be connected? I thought they were for charging the trailer while it is connected to the truck.
4. Can I run the trailer brake wire straight to the controller or where do I find the connecting wire if I cannot do that, (Assuming it is not connected at this time.).
Thanks all for your help. I really hate wiring, but am capable. What I really hate is that someone paid U-Haul to make this ridiculous mess under the truck. any assistance will be greatly appreciated.
Mark
Old 05-13-2014, 06:39 PM
Rep:2616
I won't even try explaining trailer wiring
This is a good reference site to check out
http://www.etrailer.com/faq-wiring.aspx
Old 05-15-2014, 01:57 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
Originally Posted by mookiex4 View Post
Hi all,
1. Does the trailer have to be grounded to the truck through the ball and receiver of the truck? No, the Trailer grounds out through the trailer connector (White Wire)
2. If the trailer relay fuse is blown will that affect the electric brakes? If it is, then how do I test it? Swap with a known good relay
3. Do the black and white wires have to be connected? I thought they were for charging the trailer while it is connected to the truck. White Wire is Ground; Black is main power.. both have to be hooked up in order for the electric brakes to work
4. Can I run the trailer brake wire straight to the controller or where do I find the connecting wire if I cannot do that, (Assuming it is not connected at this time.) trailer brake wire is Blue, and can be run by itself from the controller to the Trailer connector.
I hope this helped you
Old 05-21-2014, 10:02 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Nice reply Slim
Old 05-24-2014, 06:34 AM
Color: Blue
Rep:95
Thanks Warlock... I really enjoy wiring... just got done wiring my Ram up with a new brake controller... I used an adapeter harness from NAPA, which made installation very strait forward and a breeze. I was expecting a 2 hour job from start to finish.. but the harness allowed me to have the install done in about 30 minutes (to include me stumbling around on where I wanted to mount the blasted controller).
