I've got issues! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 05-15-2014, 09:03 AM
altaboy's Avatar
altaboy altaboy is offline
Vehicle: 2011 Ram s/b reg cab
Rep:47
altaboy is on a distinguished road
Default I've got issues!
Sitting on the side of the highway as I write this...was cruising at highway speeds on my way to pick up my L&M transmission, edge torque converter and jba long tube headers when the engine started to run very rough and a very loud ticking/knocking started coming from my drivers side valve cover area. Waiting for a tow truck at the moment but anybody have any suggestions other than broken valve spring/lifter or connecting rod? Engine hasn't thrown any codes but will not run :s
Ripped and lowered AWD reg cab
Old 05-15-2014, 09:57 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
I don't think it's a lifter, mine had a lifter go out which killed the cam, it still ran fine, just tapped loudly at idle. Hope once you remove the valve cover the answer will be obvious and an easy fix. I think a broken valve or dropped valve seat would be more catastrophic. Fingers crossed, it's not expensive.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 05-17-2014, 07:14 PM
Mikel Mikel is offline
Vehicle: 2006 Dodge Ram Quad Cab
Trim Level: SLT Lone Star
Mikel is on a distinguished road
Any verdict yet?
[IMG]http://mikel.com/images/Image2.jpg[/IMG]
Old 05-18-2014, 12:13 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
broke a valve spring, dropped a valve an killed a piston...just a guess though... lets just hope the valve just got slapped around...I've had 2 buddys with the same sound with totally different outcomes... first one was what I described, the 2nd one actually broke 3 valve springs at the same time but luckily didnt drop any valves, so all we did was pull the heads and replaced the valve springs....
the one that only broke a spring..
a few guys in the club went over to his house and we swapped his springs out...
Old 05-18-2014, 12:15 AM
chefred112's Avatar
Rep:656
easiest way to check is pull a valve cover and check..
Old 05-18-2014, 09:48 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Sorry to hear another Brother down man.
I'm getting out before my Hemi is next,
I Just killed my 3rd transmission and I'm going back to stock.
http://www.ramforumz.com/showthread....10#post1414210
Old 06-04-2014, 12:53 AM
altaboy's Avatar
Rep:47
We'll looks like its a bent valve and snapped piston ring. I've got a couple different options now, I talked to HHP today about stroking it out, wouldn't be cheap but it is VERY tempting. Or I could get the engine done locally, I'm booked at a local shop next week. I could get them to do bare minimum, go back to stock, sell my L&M trans back to Mike and hang my head in shame. Anybody care to chime I'm all ears...
Old 06-04-2014, 08:05 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1056
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I say stroke it!! if you are willing to spend the money that is.. how much cheaper would the local shop be to do the motor work, and how capable are you at assembling yourself? It would definitely be well worth it IMHO
Old 06-04-2014, 04:49 PM
db1 db1 is offline
Vehicle: 2010 dodge ram
Trim Level: sport
Color: mineral grey
db1 is on a distinguished road
keep your head up and stroke it! build the motor how dodge should of.
DOSNT ROLE ON TEENAGE RIMS!
Volant cai , bt catch can,180 stat, Moes 85mm, Sonnex line booster, Superchip programmer Tranny upgrade , Bilstein shocks 25% stiffer springs, Air bags, 22" srt10 replicas matt black, magnaflow tru x muffler.
Old 06-18-2014, 04:59 PM
Saltillo Express's Avatar
Saltillo Express Saltillo Express is offline
Vehicle: 1998 Dakota RT 178K miles
Saltillo Express is on a distinguished road
save the money. Build it back right, but mill the heads, thinner head gasket, bump compression, and bump the cam up some. Port the heads while they are off. And for pete's sake - spend the money on the valve locks. Sorry to hear about it friend.
Chance
