04 Hemi - cooling system overhaul - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 05-18-2014, 01:34 PM
JohnJr30236 JohnJr30236 is offline
Vehicle: 2004 Dodge Ram
Trim Level: QuadCab SLT Off-Road
Color: Dark Blue
JohnJr30236 is on a distinguished road
Default 04 Hemi - cooling system overhaul
I bought my truck used and it now has 160k miles on it. I want to overhaul the entire cooling system. Here's the parts list I have so far, can yall help if I'm missing something:
Radiator (new)
Radiator Cap (16 psi)
Water Pump (new reman.)
Thermostat (203*)
Upper and Lower radiator hoses
Coolant (18.7 quarts)
Also, should I step down to a 190* thermostat? Is cooler better? Should I stick with the Mopar coolant or since I'm going all new is normal ethylene glycol ok?
2014 Ram 1500 Black Express RCSB 3.6L 8-spd
Old 05-21-2014, 06:00 AM
thunderhawk's Avatar
thunderhawk thunderhawk is offline
Vehicle: 2005 Dodge Ram 1500 QC
Rep:6
thunderhawk is an unknown quantity at this point
As For The T Stat the ECM/PCM Is set for Optimum Performance with A factory spec Temp T Stat so If It Calls for a 195 Id go Back to Same temp and As For the Radiator to Same Some Cash Id See A Shop About Having that One Roded out as they call it its about 50 buck to do around here and you plan to do all that Id Change Heater Core Hoses too
Old 05-21-2014, 01:36 PM
Color: Dark Blue
203 is listed as factory temp. I did get heater hoses. New radiator was $82 from Rock Auto.
