Vibration over 45mph - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-21-2014, 10:07 PM
Sh40674 Sh40674 is offline
Vehicle: 2006 dodge ram
Sh40674 is on a distinguished road
Default Vibration over 45mph
Ok I have a vibration in my 06 4x4 1500.. All new ball joints and tie rod ends and wheel bearings... New tires, still vibrates. Any common problems with these? I know my cv joints are getting bad... Happens over 45. New u joints in the driveshaft too.. I'm at a loss lol. Any ideas? Wheel doesn't shake, just vibration in the steering wheel but no movement in it
Old 05-31-2014, 06:31 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
could have lost a wheel weight. could be a large stone in the tires. could be a broken belt in a tire and like you said cv joints. can you feel any play if you try to shake the cv axle?
Old 09-09-2014, 12:49 PM
kurtmann kurtmann is offline
Vehicle: 2008 Dodge Ram
kurtmann is on a distinguished road
Default Mine was a wobble
I had a similar problem. The solution will depend on just what kind of vibration it is. Mine felt like out of balance or out of round tires. I took it back to where I had the tires installed at least three times to have the tires rebalanced with no improvement (and countless alignments). Finally about a month ago (this problem has been around for about two years!) I took it to my local Les Shwab. They did a road force balance (or dynamic balance) and the problem is fixed. My truck has never driven so well. My problem was worst at freeway speeds. Hope this helps!
-Kurt
Old 09-18-2014, 05:58 PM
89gtcs 89gtcs is offline
Vehicle: 2006 Ram 1500 4x4 SLT Quad Cab
89gtcs is on a distinguished road
90% of the time these issues are caused by tires. I'd get them rebalanced. Have the tire shop strip all the weights off and start fresh
2006 Ram 1500 QC 4x4 5.7 Hemi - 139,300 miles
Old 09-18-2014, 06:47 PM
RayK RayK is offline
Vehicle: 2014 Ram 2500 Laramie
Rep:78
RayK will become famous soon enough
Definitely have your tire Road Forced balanced if you problems.
My other thought would be the driveshaft got dinged when replacing the U-Joints. I did that once by accident. Had to have the tube replaced by having the yokes welded on a new tube. It was like 200 bucks.
Old 09-25-2014, 12:15 AM
Lectus Lectus is offline
Vehicle: 2007 Dodge Ram
Color: yellow
Lectus is on a distinguished road
My problem with this was the rims themselves 20 inch oem rims were bent at the center and non repairable. I got a set of replica rims and the speed vibration stopped. When you go get them balanced get in the shop yourself while the wheel is on the balancer and if you the wheel straight on the balancer you'll see a hop or a side to side wobble in the wheel then that's your vibration problem. These aluminum wheels suck. Even one of my replica gotta replaced due to potholes in the satx streets.
