Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-04-2014, 11:30 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Posi Traction is GM's version of a limited slip,
Jeeps (Dana axles) call it Trac-lok, for Fords its Traction Lock, Chrysler is Sure-Grip.
For a Ram, the limited slip from the factory performs the exact same function.
In the old (pre 11' Rams) the Corporate 9.25" rear diff LSD was built by Auburn.
Not sure who builds them for the new ZF rear ends.
If you want a true Locker, that would be something a real off roader would use,
in the way of an aftermarket Detroit Locker, Power Trax no-Slip, Lock-rite, or a full spool or air activated ARB.
I've used a variety of these, the stock limited slip (anti-slip) is all you'll ever need for street use.
It uses a clutch activated system to engage the other side when slip is detected.
The down side is the frictions eventually wear out.
A better built limited slip is available through Detroit (Eaton) in a TruTrac
which uses a spring loaded helical gear engage system.
Old 06-04-2014, 11:46 PM
Rep:554
Originally Posted by HammerHead View Post
Could you explain the equation in more detail for me Please?
Is it tire height divided by ? = 1.3 X the rear ratio = calculated rear ratio?
Originally Posted by CHVYKLR View Post
He's saying that when he switches his 33" tires for his 27.5" track tires it's the equivalent of changing the rear gears from 3.55s to 4.26s.
Your new tire size is only 3.1% shorter compared to the stock 275/60-20 tire which equates to a 3.66 effective gear ratio
Bingo!
sorry if my first post was not clear
Stock tire size (33) divided by smaller tire size (27.5) = 1.2
Now multiply your current gear ratio by that factor (3.55 x 1.2 = 4.26)
as I first mentioned,
There was also a weight reduction and lower rotational mass
by dropping the rim size to 17" (from heavier 20" wheels)
So I drop about a half a second over a quarter mile.
Simply dropping from 33" 275/60R20 to a 32" 305/50R20 is not going gain anything.
The extra weight of the wider tire likely offsets anything you gained by dropping an inch in diameter.
Stock 275/60R20 Good-for-a-Years weigh about 40lbs ea.
My 305/50R20 Terra Grappler's are 49lbs ea.
(Nitto 420s are 46lbs ea.)
Old 06-05-2014, 09:33 AM
HammerHead's Avatar
HammerHead HammerHead is online now
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
HammerHead is on a distinguished road
Learning so much from you guys, thanks for taking the time and good info
Geared and Tuned (Greene Racing Motivation)
Proud member of the 4 second club...
Old 06-13-2014, 12:44 PM
Hemi4Door Hemi4Door is offline
Vehicle: 2014 Ram 1500 Express
Hemi4Door is on a distinguished road
I have the 3.21 rear gears and the 8 speed. I want to upgrade to 4:10's and posi. Is that possible with my truck?
Old 06-13-2014, 06:07 PM
HammerHead's Avatar
USMC 0313
Vehicle: 2013 RCSB
Color: SILVER
Rep:20
Yes you can!!! I would get a build sheet for your truck to be sure you have a conventional / open diff before you buy the parts. LSD and Posi traction are the same thing. So if you have the LSD all you would need is the gears. However the 8 speed tranny is by far the best with better low end torque with the additional 2 gears. Do some research before you make the decision. I swapped my 3.55 to 4.10 and love it, but wish I went with 4.5?'s. I wanted more off the line than I got. Plus I have the 6 speed tranny that needs lots of help.
You can get your build sheet at-
http://m.ramtrucks.com/en/mobile/web...p%3Ft%3D177951
Old 09-03-2014, 01:45 AM
Kingelvis's Avatar
Kingelvis Kingelvis is offline
Kingelvis is on a distinguished road
I thought the ZF axle didn't have many aftermarket parts yet. Hope you aren't paying an arm and leg.
Just put the Yukon 4.11:1 in mine Friday 29th of August, a date to ever be known as "4.11 gear day" henceforth :-)
(though the Yukon box printout says 4.10 - curious)
Bullydog tuner says 0-100kph in 6.5 vs. 7.5 secs with my 3.21 open - and this was totally 'side of the highway' testing.
Also got the Detroit TrueTrac to replace spider gears. 3.21s really would not spin just flooring it off the mark even with the traction control off. Now with with the TrueTrac 4.11 and traction control off, it will easily spin both.
BTW, I've found the Bullydog tunes to be complete and utter poppycock.
It knocks something fierce on "Premium" setting even with 40 gallons worth of octane boost poured into 12 gallons of gas. Shifting seemed hesitant as well.
Bully dog shouldn't have the GPS with performance testing on there because it only proves the tunes do nothing ;-)
Old 09-03-2014, 02:15 AM
Kingelvis's Avatar
With 4.56 you get down near where the 8spd 3.21 1st is overall 13.70 vs 15.1:1 for the HP.
6spd 2 and 3 are so close together, but IIRC 5spd has the same ratios but skips over the 3 to 4 while the 6spd passes through 3 (highway kickdown 'passing gear') going up
People kept telling me just go with 3.92 and I always thought that was kind of odd to draw the line at 4.00. I'm only driving 7000 miles per year. Thing is this is our car for long distance travel. It now has a cap on it and we go to festivals, tourist traps and camp in it. I can't go all-in for drag gears. I'm going from 1500rpm at 60 to 1800. 4.56 would take it to 2000 at 60 and pushing 2700 at 80mph.
My hope is that if I can run 2150 at 70mph I'll still get better gas mileage than running 1950rpm at 80mph with 3.21s because the aero resistance is so much greater 10mph faster.
Old 09-05-2014, 05:18 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Originally Posted by USAF Long View Post
Changing the rear gears will throw the speedometer off. I want to change mine too but I am not messing with it til I get a tuner to take off the top speed limiter. I was going to put nitrous on my truck but if I do that it will just top out at 105 and shut down before I cross the 1/4 mile. Changing the gears I bet you could have the dealer correct the speedometer but the won't take off the speed limiter. The best bet is to do gears and get a tuner. The gears will make the truck much more snappy off the line. I'm thinking 4.10 or even 4.56 in my truck. I tow a huge boat with mine and the extra low end would really help get the boat moving faster off the line. The Hemi pulls it but it takes it a while to get into the power band. 4.56 would be great for me but I dread the fuel economy drop on the highway.
Unless ur mid 12 you will not top out your truck. Are you trying to say your truck will not go past 105? That not true either. I have 4.56 I get better miles on the highway and at 75 with 20 inch tires with 275/60/20 I only at 3k if that.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-06-2014, 11:46 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
My truck cuts out at 105 mph. Tested it on the highway and if I stay on the gas a little past the 1/4 mile it cuts out. I trap at 97 mph but that averages. Closer to actually 100 or 101 when I cross the line. Its close for comfort.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 09-09-2014, 09:06 AM
Redhemi03 Redhemi03 is offline
Vehicle: 2003 hemi ram
Trim Level: Slt
Color: Flame red
Rep:26
Redhemi03 is on a distinguished road
3.92's with a 8speed is about as low as you want to go, 4.10's and 4.56's would be a drastic over kill and you would be doing nothing but shifting the entire 1/4 mile, there's a qc hemin8 speed with 3.21's and a tune running 2.0 60' at 8.98 1/8 mile and 14.0 1/4. Plenty of gear with the 8 speed, I promise that
2003 QC HEMI. 8.46@ 79.50, fastest NA 03 QC
Sidewinder cam, power wire,Tmr delete, edge 2800, hedman long tubes , Hedman ory pipe, 3" cutout, magnaflow 24", k&n CAI,Sharadon stage 3 VB, 4.56's, superchips 91
