AC relay? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 06-02-2014, 01:48 AM
thrifty thrifty is offline
Vehicle: 2006 Dodge Ram
Color: Atlantic Blue
thrifty is on a distinguished road
Just went and watched the video again and no where did it say there was a recall. My Bad! I forgot to say in the last post, we took all the grounds off and cleaned them, Amazing that Dodge would power coat and then put a ground over the top of the paint. Cleaned them all up and greased them with dialectic grease. I am assuming the circuit board has gone out.
Old 06-02-2014, 11:58 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I'm wondering of your TPS is out of whack. When you push the pedal to the floor and ask for WOT, the computer will turn the a/c off so that you get maximum horse power. And, if you're getting really crappy mileage, I'd check in to the throttle position sensor.
Old 06-05-2014, 08:49 AM
4.7 Magnum Motorhead 4.7 Magnum Motorhead is offline
Vehicle: 2002 Dodge Ram 1500
Color: Patriot blue
4.7 Magnum Motorhead is on a distinguished road
Hmm....hate to say this, but it's starting to sound like your PCM may be going out. Judging from your mpg meter and the AC acting up like they are, which are not even related to one another electronically, guides me towards this direction. It very well could be your entire fuse and relay management, but if not that I'd say PCM. We'll stay tuned for another update!
MOPAR forever!
Old 06-05-2014, 10:47 AM
Rep:2968
Well, there's that ^^^^^^^^^^^^^^^ too.
Old 07-05-2014, 08:18 PM
TDubb520's Avatar
TDubb520 TDubb520 is offline
Vehicle: 2007 Ram 1500 4X4
TDubb520 is on a distinguished road
Hey there. Been working on a similar issue. Are you sure the compressor is not kicking on? Mine blows hot when I am not moving, my fan for the ac condenser is not running. I just returned the relay I got from autozone today, but I was opening up the TIPM when a monsoon rolled in. I will let you know what I find. There may be relays in there?
Here's a link to my post with another issue that may interest you.
http://www.ramforumz.com/showthread.php?t=179420
Hopefully we can get this figured out!
Troy
Old 03-12-2015, 11:35 PM
Been a while since I have posted anything here. I got pissed off and went and bought a new 14 Ram. So the 06 sat for about 6 months. Had my ex pool guy offer me a low price on the truck wanted to give to his son. Then he also says he wants to make payments. I hate arrogance. ( I would have let the wheels rot off before I sold it to him) So I am happy to say the truck went to a good friend of mine. So it got a good home. As soon as they fix the problem I will post about it
Old 03-13-2015, 06:23 PM
Rep:2968
Voonderbar!! Congrats on the new ride. Let's see that that new beast!!!
Old 05-18-2015, 06:56 AM
PdPuNOme PdPuNOme is offline
Trim Level: SLT/Laramie/Daytona
PdPuNOme is on a distinguished road
I think you need to also focus on other areas of the ac system as there are many components that can cause failure. Most common is the compressor itself. The clutch could be seizing up/not engaging, the high pressure sensor on the line above the compressor could be faulty, your fan could be the reason, a clog in the ac system could be it, the list goes on. faulty compressor sounds like a viable diagnose as you say your mpgs and rpms act up when it finally does run, so that hints at the compressor putting extra load/strain on the belt/engine. Keep digging I think your looking in the wrong direction that's just my two cents.
for instance, my compressor doesn't engage right now due to it being shot simple as that, no leaks, no other issues just a bad compressor. New one sitting in garage ready for a day to waste on it.
