tonneaucovered.com
Old 05-28-2014, 09:05 AM
wr986's Avatar
wr986 wr986 is offline
Vehicle: 2009 Dodge Ram
wr986 is on a distinguished road
Default Cold air intakes
Question,
I opened up my exhaust just a bit with a flow master muffler.
It has been suggested that if I then add a cold air intake I will need to have the dealer reprogram the computer. Didn't sound correct to me.
Any thoughts?
Any suggestions on a cold air intake?
Thanks
Old 05-28-2014, 12:12 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
My thought is... that's a bunch of horse pucky! But, it's also my thought that these stock CAI systems don't need any improvement. Sure, you can spend a few hundred bucks and make them sound a little better, but you won't get any measurable (butt dyno) performance out of them.
Old 05-28-2014, 12:30 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2101
Exactly what Roger said ^^ If you read around the forum a bit you'll find tons of information on it. The stock CAI will support 500 hp no problem. Plus just doing a Flowmaster swap very minimally opened up your exhaust.
Go out, disconnect your battery and touch the positive and negative wires together to discharge any current left in the system. Wait a few minutes and then hook them back up. That will reset your computer and let it relearn the truck with the new exhaust which essentially reprograms it.
Old 05-28-2014, 01:29 PM
wr986's Avatar
Default Agreed
It sounded like bull but you can never be too careful.
Has anyone seen any improvement from using a cold air intake?
Old 05-28-2014, 08:32 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
Regardless of what people say buy a cold air and go to the track. You will get 3 tenths off your time... you may not feel it a whole lot but it does work. . Just my experience. And this is cold air and exhaust only
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 05-28-2014, 08:39 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:446
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Check out the Vararam. Looks nice, can't prove it gained more hp, but I did cam and some other mods at the same time. To me worth every buck, my wife might argue, but...
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 240,000 miles To Hell and back. 14.2/96 mph NEDW
Old 05-28-2014, 09:04 PM
SweetLeaf's Avatar
SweetLeaf SweetLeaf is offline
Vehicle: 2015 Charger SRT HellCat
Trim Level: 6.2l SuperCharged
Color: Pitch Black
Rep:54
SweetLeaf will become famous soon enough
Send a message via Skype™ to SweetLeaf
I've seen some mild gains maybe 10+ HP using the K&N. Sounds nice with the exhaust
Traded 2011 Ram Sport Crew/2010 Sebring Ltd for 2015 Charger SRT HellCat FH769976
Old 05-29-2014, 12:19 AM
hemiheaven hemiheaven is offline
Vehicle: 2005 Dodge Ram SLT
Trim Level: Daytona
Rep:12
hemiheaven is on a distinguished road
I would invest in a tuner first. Diablo Sport (or the like) will definitely give you seat of the pants for the money!
Volant PowerCore CAI, efan, 180 tstat, Pacesetter Lt's, Pacesetter y pipe, Hemifever 93 tune, 87mm throttle body, 4.56 Yukon posi.
Coming soon....Torque converter and drop
Old 05-29-2014, 09:41 AM
twooldfarmers twooldfarmers is offline
Vehicle: 2014 Laramie 5.7 Hemi Crew
twooldfarmers is on a distinguished road
the so called CAI .....
in actual fact what you are doing by installing one is putting on a HAI
the OEM air boxes draw air from a cooler (denser) air source outside of the engine bay whereas the Hot Air Intake kits use a less dense hot air source and actually result in a loss of horse power under most under hood conditions
the increased induction noise sounds good and gives us a false sense of 'goin faster' but the reality is vastly different from the sale hype
you don't need to be an engineer to figure out the logic behind this
manufacturers won't spend one thin dime on anything they don't have to and it costs a fair bit of money X's say 200,000 trucks annually to pipe cooler air to the motor, the reason for this is drive-ability and increased efficiency
bottom line is forget the Hot Air Intake system
Old 05-29-2014, 10:38 PM
Rambone Rambone is offline
Vehicle: 2005 dodge ram daytona
Color: silver
Rambone is on a distinguished road
cai's and ram air intakes are all about getting more air into the engine, And when you are driving down the road the wind supplies the cai or ram air intake with fresh cool air. And obviously the more mods you have done, the more efficient the engine will be.
