2006 Ram 4.7L mechanical to electrical fan conversion - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 05-31-2014, 12:23 AM
Jimmyfishfl Jimmyfishfl is offline
Vehicle: 2006 Dodge Ram 1500
Jimmyfishfl is on a distinguished road
Default 2006 Ram 4.7L mechanical to electrical fan conversion
I've been reading through the forums about replacing the mechanical fan and clutch with an e-fan for the radiator. I've read that the some guys have been using a 3.7L/v6 fan assembly for the radiator and condenser. I'm trying to find if the condenser fan will need to be replaced as well or is the new unit all in one. Also looking for the part numbers to order the new parts/kit and where's the best place to find and order. Thanks!!
Old 05-31-2014, 01:37 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Welcome to the Ram ForumZ, Jimmy. I invite you to stop by the Newbie Check In section and introduce yourself so other members can give you a proper howdoyado.
This is one of the mods I've been thinking of doing myself as well. Get a little extra hp from the engine. From what I understand, it is fairly simple.
Old 06-09-2014, 03:04 PM
rcflyer8410 rcflyer8410 is offline
Vehicle: 2004 Dodge Ram
rcflyer8410 is on a distinguished road
Default Radiator fan
Probably one of the most common electric conversions is the Flex-A-Lite (for yours, this is the flex-a-lite 183). This is a direct fit. This only replaces the mechanical fan for the radiator - no reason to replace the electric fan for the condenser.
A word of advice - do your research well. For typical driving, e-fans work great. However, if you tow or drive under load in hotter weather (up hills, heavy loads, etc..) I have found people run into problems. Flex-A-Lite's web site even recommends sticking with a clutch fan if you frequently tow. The mechanical fan can deliver more airflow than an electric fan - especially when you are towing, up hills, higher RPM's and temps... Just do some google searches for "dodge ram towing electric fan".
I have personal experience with this. E-fan worked great for normal driving - better than the clutch fan. However, combine warmer temps, towing, and mountain grades, the E-fan simply could not keep up.
