Old 05-31-2014, 07:08 PM
bmax1985's Avatar
bmax1985 bmax1985 is offline
Vehicle: 2007 Dodge Ram Sport 4X4
bmax1985 is on a distinguished road
Default Can't get heater hose loose.
Over the winter I found my truck a bit low on coolant during a snow storm. I topped it off with the 'universal' coolant and was then chastised on forums for doing so due to potential issues. Not wanting to leave it that way, I purchased the Prestone 'Flush and Fill' kit.
The kit has you cut the heater hose 'to the top of the engine' and leave the T that came with the kit in permanently. Being leery of leaving my cooling system in the hands of a cheap Chinese plastic T, I planned to remove the heater hose with the words 'top of engine' and temp in the T, flush the system, then reconnect the factory hose.
Trouble is that I can't get the hose off. My questions:
How often should the hoses be replaced? Mine's an '07 and I believe the original hoses. (Im not the original owner). they feel soft but not exceedingly so.
Has anyone had luck removing the hoses with one of the removal tools that looks like a bent screwdriver / ice pick?
Anyone done this and have another idea?
Thanks,
Brian
- Brian
Old 05-31-2014, 08:23 PM
Rep:2657
In the past,
5 years has been recommended for hoses & belts
i believe tires that are exposed to the elements & a 12 volt battery could be added to the list, but no one would just change the tires & battery just because they turned 5
Just cut the hose off, but don't use enough pressure to cut into the plastic of the radiator
Old 06-01-2014, 11:54 AM
bmax1985's Avatar
I figure if I'm replacing hoses it's worth the extra $25 or so to do the upper and lower radiator too just for good measure. Anything else I should do while I"m at it? The HOAT coolant is freaking expensive so the plan will be to not open it up for another 7 years or so... Of course by then the radiator will probably fail.
- Brian
Old 07-16-2014, 07:50 PM
Ramhahdah Ramhahdah is offline
Vehicle: 2002 Dodge Ram
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Ramhahdah is on a distinguished road
You may want to consider changing the thermostat while your at it.
